Passive 3D Displays and Devices in 2020
CameraTraveler27
There a amazing amount of technical knowledge on this forum and after my research I'm having a hell of a time finding any 2D/3D displays that use passive 3D polarized glasses. Surely someone is still making them or are available in the aftermarket. The ideal device would be a either be 4K portable display roughly around 15" OR a Windows 10 tablet (or 2-n-1) with about a 15" 4K display. Any leads or keywords you can offer me to help find what I'm looking for would be very appreciated.
Re: Passive 3D Displays and Devices in 2020
For passive, there's a variety of small ones; stereoscopic (2-image) or "holographic" (full side-to-side parallax)?
https://www.magnetic3d.com/products/displays/
https://lookingglassfactory.com
Have you considered active 3D? They work on most high-Hz gaming monitors, with some hacks. Usually stereoscopic displays use a strobe backlight so you can commandeer a display's motion blur reduction mode to do the same thing. But a workaround can be simply sheer Hz -- a generic 240Hz panel can double as a 120Hz shutter-glasses display using software BFI (left-black-right-black frame sequence), using black frames for the shutter-glasses switch time. You will need a shutter glasses controller that can adjust phase/delay. This can be somewhat of a hacky solution.
CameraTraveler27
Thank you! I took the time to research the two links you provided and unfortunately Magnetic 3D Displays only make glassesless displays and nothing around 15". Looking Glass is amazing but the kind of content that is compatible with their displays in more 3D models and not VR content. Looks like my best bet is to use active shutter 3D glasses with this 17" 120Hz TN LCD for my portable application. Specs I wouldn't have known to look for without your help so thank you. https://www.amazon.com/dp/B07YBV8RQM/?c ... _lig_dp_it
We also need to create a more stationary, large sit down Three monitor setup. Two final questions I have for you are can active 3D glasses work with a LED (not LCD) display if it's 120Hz? I ask because there are a lot more very affordable large LEDs rather than LCDs.
The other question is if VRR, G-Sync or FreeSync absolutely needed for a display when using Active shutter glasses or would the variable nature of these three technologies actually make the shutter glasses go out of sync with the display?
Try a 240Hz TN portable screen with a large blanking intercal (Vertical Total 2250) in Custom Resolution, to allow 120Hz refresh cycles to scan in only 1/240sec so your glasses shutter can be open for a longer period (4ms or so) on completed refresh cycles, since not all pixels refresh at the same time, www.blurbusters.com/scanoutCameraTraveler27 wrote: ↑08 Oct 2020, 15:25Thank you! I took the time to research the two links you provided and unfortunately Magnetic 3D Displays only make glassesless displays and nothing around 15". Looking Glass is amazing but the kind of content that is compatible with their displays in more 3D models and not VR content. Looks like my best bet is to use active shutter 3D glasses with this 17" 120Hz TN LCD for my portable application. Specs I wouldn't have known to look for without your help so thank you. https://www.amazon.com/dp/B07YBV8RQM/?c ... _lig_dp_it
- the need for fast GtG
- the need for a guard period (long VBI or strobe backlight) during eye change
- the need for less crosstalk
- the need for a brighter image.
I also provide consulting services on 3D glasses systems, see https://services.blurbusters.com and contact me [email protected] .... as Present()-to-Photons expert ourselves, we can guide a business on such matters.
Refresh rate headroom is your best friend in reducing 3D glasses crosstalk for a non-strobed LCD
VRR is incompatible, unfortunately with active shutter glasses. In theory, passive 3D can be done with VRR.
There are many possible options, but also easy to go the wrong route because of a missed consideration.
CameraTraveler27
Thank you Mark. I'm interested in purchasing some time for a phone consultation. I'm available today and just sent you a email with my details.
Emailed. I'm already helping multiple 3D vendors on the confusing Present()-to-Photons black box.
Note: I prefer video calling, as I am deaf, and all my video software (Zoom, Skype, Discord) have closed captioning features or plug-ins nowadays.
RonaldKTM
Hi Mark,
Just new to this site and forum.
I am looking to customize/develop a simple dichoptic stimuli (eg gray background both eyes and "R" seen by the right eye and a "L" seen by the left eye) at 40 cm and 4 M viewing distance, with an active shutter system.
What do you suggest? I am pleased to take this offline and invest in your services.
Ron
Ron
Hello Ron, you may contact [email protected] for Blur Busters Services. I have worked with multiple stereoscopic 3D clients.RonaldKTM wrote: ↑27 Jun 2021, 07:37Hi Mark,
Thank you!
LiguFlo
Here are some passive monitor options.
They are costly. The contour does not require glasses, but you need to sit in front of it at a specific angle for it to work.
Vision Engineering Contour
VrLogic SeeHawk
Schneider PluraView
Vision Engineering Vectour
There are some DIY guides for making your own beam splitter. Maybe worth a try if you're handy... The monitors used are not actually all that expensive, from what I read.
VrLogic SeeHawk
Schneider PluraView
BlackMyth
Given that they are inexpensive glasses with an inexpensive system, they probably can tolerate some aberration. Will watching a 3D movie cause you to notice minute image problems? The plastic film-based products are also much less expensive than things like quartz.
In addition, I'm sure economies of scale play a role.
