Do I need a good PC to test monitor?
Multiplex
Post by Multiplex » 26 Nov 2020, 16:51
I’m thinking about getting the Lenovo Y25-25 (240Hz), but don’t have a pc to test the ghosting and or visible overshoot. What I do have is a laptop with a GTX850m on it, but I don’t know if that would be enough to test it in the ghosting ufo test seeing as it’s 240Hz refresh rate. Can anybody tell me if I’ll be able to get 240fps on the test with alaptop from 2015? Thanks. :)
Re: Do I need a good PC to test monitor?
Post by RealNC » 27 Nov 2020, 11:49
Most probably yes, unless your laptop does not support 240Hz output. You need to check the specs of your laptop and check the maximum resolution and refresh rate of its external display output.
Multiplex
Post by Multiplex » 27 Nov 2020, 16:23
Hey thanks for the reply, it really helped! One thing I need help with is finding what generation my hdmi port is. I cannot find it for the life of me.
Boomchakadah
Post by Boomchakadah » 30 Nov 2020, 20:58
Multiplex wrote:
27 Nov 2020, 16:23
You need DisplayPort or HDMI 2.0 to run 240hz. HDMI 2.0 support started with GTX 900 series cards. (Your 850M is limited to HDMI 1.4)
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Post by Chief Blur Buster » 01 Dec 2020, 17:02
Boomchakadah wrote:
30 Nov 2020, 20:58
Multiplex wrote:
27 Nov 2020, 16:23
You need DisplayPort or HDMI 2.0 to run 240hz at 1080p. HDMI 2.0 support started with GTX 900 series cards. (Your 850M is limited to HDMI 1.4)
Fixed that for you.
DP and HDMI has no inherent refresh rate limitation, except limitations imposed by EDID spec, drivers and operating systems. I've seen really high refresh rates done at really low resolutions on some displays.
However, it is indeed easier with newest equipment, since they're less likely to have arbitrary caps on refresh rates that prevent you from using a higher refresh rate.
