Hello, I would like to get help with purchasing a new monitor for my computer, its for gaming i perfer ips panel, but itsnt must, my eyes is sensitive to ULMB and that kind of stuff and causing me headache(from my xp with xl2546 dyac- reddish burning eyes).
if u got any suggestion
im looking for display with good response time that also good for the eyes and has good color celebration(something for fps/moba gaming)
Hello i need recommendations for good display without ULMB
Re: Hello i need recommendations for good display without ULMB
If you have bad experience with strobing -- and want IPS + good colors,
You'll probably do well with one of those 240Hz-thru-360Hz IPS monitors.
The 280Hz VG259QM (with ELMB turned off) could be right up your alley, because it has had good out-of-box color calibration, while having less motion blur than an XL2546 DyAc=OFF. (The 280Hz overcomes the IPS-vs-TN differences).
The 360Hz has even less motion blur than the 280Hz, but begins to have slightly asymmetric motion blur (leading and trailing edge), so if you want more symmetric motion blur, the 280 Hz ASUS tends to have a slight edge.
What do you mean by asymmetric motion blur? Is it a bad thing?Chief Blur Buster wrote: ↑07 Jan 2021, 17:50If you have bad experience with strobing -- and want IPS + good colors,
No. It's a form of ghosting -- different pixel response speeds (GtG) for different colors -- which can create a bit more ghosting/blur on one edge than the other.
Some people don't mind since both edges is far less motion blur than lower-Hz monitors, but many people prefer motion to be clean (symmetrical GtG pixel response at leading and falling edges).
It's extremely slight and you might not notice it. Just that 240Hz-to-280Hz IPS doesn't puch IPS GtG limitations as much as 360 Hz does.
Hey Chief, I'm buying either the VG259QM or XL2546K next week and your comment surprised me, I do know Colors, viewing angels in the asus (since IPS) > the BenQ, input lag/responses time probably fair to say a tie, DyAc > ELMB, but Motion clariy you give Asus the edge? Is it because DyAc/ELMB OFF simply 280Hz IPS > 240Hz TN? or even both at 240Hz motion clarity/blur is better on the asus?Chief Blur Buster wrote: ↑07 Jan 2021, 17:50If you have bad experience with strobing -- and want IPS + good colors,
And last small question sorry for off topic, Do you know if the Panel in the BenQ XL2546K is the same one as in the Lenovo TN 240Hz 1440P? (27GQ-25)
Thanks a lot!
Yes, higher refresh rate with similar pixel response will have less motion blur. However, the motion look is a personal preference. A number of have reported more symmetrical GtG (same blur on leading/trailing edges) on the 280Hz ASUS than the 360Hz ASUS, despite 360Hz having less motion blur.
Unless you're earning money in competitive gaming and need to be consistent with what your competitors are using, they are pretty close and it really boils down to a personal preference.
Clearly pros/cons of the differences between the ASUS and BenQ, so many will swear one way or another, depending on your priorities/preferences.
If you are not picky about TN versus IPS, the XL2546 series is certainly in play.
No, it is not possible that the 1080p XL2546K panel is the same as the 1440p Lenovo panel, because they're different resolutions.
