ASUS TUF GAMING VG279QM
elexor
Re: ASUS TUF GAMING VG279QM
Post by elexor » 15 Mar 2022, 19:07
Discorz wrote:
15 Mar 2022, 14:59
Nice guide. that's pretty much what I use for low hz strobing on the 279qm, worth mentioning theirs additional lag reductions possible in games by using rtss scanline sync in conjunction with high vertical total modes.
Discorz
VIP Member
Post by Discorz » 07 Jun 2022, 11:06
VG279QM @240 Hz 240 FPS, OD 0, 960 pps
VG279QM @240 OD OFF.jpg (442.37 KiB) Viewed 22479 times
VG279QM @240 Hz 240 FPS, OD 80, 960 pps
VG279QM @240 OD 80.jpg (458.79 KiB) Viewed 22479 times
MatrixQW
Post by MatrixQW » 01 Jun 2023, 10:03
I just received this monitor.
The ufo test stutters in a fixed interval of 7 seconds since it occurs, always from 280 to 268fps.
Tested frame skipping with my phone and I think it's working properly.
I thought it was something in Windows so I did a clean install without touching absolutely no setting but same is happening.
Don't know if it's software, hardware or Chrome.
Happens at 280Hz, 240 and 144.
Have cpu and gpu at full frequency.
If anyone has any idea how I can find the problem I would appreciate it.
d4rthvdr
Post by d4rthvdr » 17 Jul 2023, 01:25
Discorz wrote:
09 Feb 2021, 06:44
Chief Blur Buster wrote:
09 Feb 2021, 04:09
That's some fantastic pursuit camera testing of the VG279QM.
Glad the Chief likes it :D
Hello. Im very interested... why do they add the PWM section in latest MCM ? what's the best value for PWM?
regards
