Hi my pc:108500K stock 4800mhz
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
Drivers 461.72
I have updated Windows 10 to H20,the newest version. I installed windows 1 month ago with new pc. So far so good,games not crashing all stable.My pc is on 24 hours. Today was idle 5-6hours in desktop. After few hours when i go to use pc, i run Google chrome and then all starts slowly responding. I mean i was able to touch/move mouse, but all stops slowly responding. Chrome,search bar,start button stops responding. When i make CTRL ALT DELETE ,then black screen apeared with blue circle ( instead of mouse arrow ) and then mouse stops responding and keyboard. Caps Lock stops worked. So Windows 10 get locked.So i force hard reset.
Is there somewhere my pc not stable or its a windows thing?
Like i said pc was idle 5-6 hours ,when i go to use pc, i turned on google chrome and then all starts slowly hanging. I checked EVENT VIEWER: Nothing,0 entries about any errors.Thx.
ah ps
NZXT cam was on background and epic launcher + steam.
PS:Karhu Ram Test for 3 hours finished without errors. Dont have crashes in game.
Pc is not overclocked. Only XMP on.
Windows 10 hang after long time idle
- RealNC
Re: Windows 10 hang after long time idle
If it only happened once, I'd forget about it. Some kind of fluke.
Also, you should do a full reboot from time to time, not just hibernate. Windows isn't the most stable OS out there when running for extended periods of time without a full reboot. Full reboot, not quick reboot (aka "fast startup".)
sew333
Hello RealNc. Thank you for reply. Yes it happened once,not repeated since. I tested all games: battlefield 5, quake 2 rtx, control,Serious Sam 4, Metro Exodus no issues , no crashing.
So no worries about that one fluke?
