darkstorm wrote: ↑25 May 2021, 12:08
Will the XG2431 work simultaneously with BFI and VRR?
Simultaneous strobe+VRR is not supported in XG2431.
You can instead, alternatively use Quick Frame Transport (VT4500 60Hz) + RTSS Scanline Sync, to get similar low strobe lag if using a PC-based emulator. That can produce lower input lag than the original machine (and MiSTeR), because a 60Hz refresh cycle is transmitted over the video cable in 1/240sec, and refreshed onto the screen in 1/240sec. A bit of a latency cheating, but it's a feature of 240Hz panels with custom quick-refreshing 60Hz modes (like using capped VRR or using Quick Frame Transport).
Custom fixed-Hz and strobe is supported in an analog continuum from 59Hz to 240Hz, so you can use any Hz such as 83.2456 Hz or whatever custom rez your MiSTeR outputs, as long as within that range. You don’t necessarily need VRR to support custom fixed-Hz.
Also MiSTeR doesn’t support VRR anyway.
You probably meant to ask “Does XG2431 support BFI at odd refresh rates output by MiSTeR?”.
The answer is YES! As long as the fixed Hz is within 59-240 Hz.
