Monitor 2k 24/25" for gaming
Merk91
Post by Merk91 » 08 Jun 2021, 04:21
Hi,
does someone know if exsist some monitors in 1440p but 24 or 25" for gaming? maybe 144Hz or better 240Hz?
i know that there are a lot of 2k 27" 144/240Hz, but for me is too big for gaming
Discorz
VIP Member
Re: Monitor 2k 24/25" for gaming
Post by Discorz » 08 Jun 2021, 04:35
Use DisplaySpecification Display Finder and set what you need to search for. There are 5 monitors, all from 2016.
Merk91
Post by Merk91 » 08 Jun 2021, 14:38
Discorz wrote:
08 Jun 2021, 04:35
In your opinioni, why no One produce 24/25" 2k right now? The image appear too small? If i compared an 2k 27" and 25" 1080p there Is a loro of difference on image dimension? Im scared about the dimension of the 27
Discorz
VIP Member
Post by Discorz » 08 Jun 2021, 15:21
Its because combining "premium" resolution with average screen size would be considered as a weird combo, combining expensive and cheap. 1080p on 25" has a pixel densitiy of 90 pixels per inch, 1440p on 27" is 109 pixels per inch. 1440p 27" has smaller pixels so it looks nicer but I personally don't care about density so I got my self 1080p 27" (VG279QM) and its perfectly fine for me. Its hard to demonstrate the difference that is why u can't find a good comparison online. Most people don't like smaller pixel density.
Merk91
Post by Merk91 » 08 Jun 2021, 16:04
Discorz wrote:
08 Jun 2021, 15:21
Im in truble with screen dimension..Always play on 24/25" monitor.. Just try a Samsung g7 but i dont likes the feeling.. there Is a lot of screen in front of my face ... With 25"monitor Is All under my eyes..with 27 im scared that It could be too big and i cannot see all
Discorz
VIP Member
Post by Discorz » 08 Jun 2021, 17:10
Merk91 wrote:
08 Jun 2021, 16:04
Maybe the 1000R curve is messing with you on G7 since it pushes the edges of the screen closer. Try pushing it further away on your desk if you have the space. Maybe flat 27" screen would suit you better. But if you like 25" more than go for it if it completely satisfies you. I would personally avoid 25" nowadays for either casual or competitive gaming.
What games are you playing and what gpu, cpu do you have?
Merk91
Post by Merk91 » 08 Jun 2021, 19:03
Discorz wrote:
08 Jun 2021, 17:10
Merk91 wrote:
08 Jun 2021, 16:04
I usually play warzone, Cod multiplayer and valorant sometimes. My PC have ryzen 7 5800x and zotac rtx3090.
I see the 2k 25" in the First link, but the are so pricey and so old, maybe panels are not so good
Discorz
VIP Member
Post by Discorz » 09 Jun 2021, 01:25
Thats a beast pc. Thats a pc for 1440p gaming. Don't cheap out on monitor. Buy 27" 1440p with fast IPS panel.
Yes those 1440p 25" monitos are old TN panels from 2016.
Here are some recommendations:
27" 1440p 240+Hz IPS:
AW2721D
PG279QM
XB273U GXbmiipruzx
27" 1440p 144+Hz IPS:
27GP850
S2721DGF
Omen 27i
MAG274QRF-QD
Merk91
Post by Merk91 » 09 Jun 2021, 03:57
Discorz wrote:
09 Jun 2021, 01:25
AW2721D
PG279QM
XB273U GXbmiipruzx
27GP850
S2721DGF
Omen 27i
MAG274QRF-QD
thanks! unfortunatly lot of these monitor are not available here in italy.. how about these:
LG 27GN850
VG27BQ
XB273U GSbmiiprzx
aorus f127q-p
GIGABYTE M27Q
Discorz
VIP Member
Post by Discorz » 09 Jun 2021, 05:22
Not sure but 27GN850 should do fine.
