Help with weird Mousetester Graph
dbc_lx
Post by dbc_lx » 10 Jun 2021, 06:28
Hi,
I just performed some tests with mousetester (purely out of curiosity, cause the mouse felt weird to me switching between 500 and 1000 Hz) and because i wanted to see how the Orochi v2 performs, then I got this at 1000Hz:
and a pretty normal result at 500Hz:
I was doing smooth, slow swipes in the shape of a 90° turned 8. Can someone help me make sense out this, i've never seen a graph like the on at 1000Hz before. Thanks in advance, Alex.
Re: Help with weird Mousetester Graph
Post by Chief Blur Buster » 11 Jun 2021, 13:44
Make sure you rule out possible USB contention.
Try playing port lottery. You might be getting contention between multiple USB devices.
Try an external USB3 card.
Related thread: viewtopic.php?t=7618
Post by Slender » 14 Jun 2021, 16:26
ha-ha
wadge
Post by wadge » 02 Dec 2021, 11:35
Slender wrote:
14 Jun 2021, 16:26
ha-ha
How did you achieve that ?
timecard
Post by timecard » 02 Dec 2021, 23:01
That plot doesn't look proper but it could be stable, when the plot is stable with few spikes it should look similar or "better" than the screenshot I posted. Probably just needs to adjust the start point from 0 to 1 and it'll auto adjust the plot.
Wrote this not long ago, may help you get started.
https://www.overclock.net/threads/what- ... t.1795211/
