Bugged UFO ghosting test speed at 390Hz
Discorz
VIP Member
Post by Discorz » 05 Jul 2021, 16:16
Hi Chief,
Users have reported bugged ufo speed at 390Hz (Acer XV252QF).
VisorizoR wrote: ↑
01 Jul 2021, 19:18
In the ufo test the standard 960 pixel per second speed is bugged on 390 HZ.... it apears slower moving...
so its unfair to compare this against other 360hz monitors...
but on 1080 pixel per second the ufo moves about the same speed on 390 hz vs 960pixel on 360hz
BTRY B 529th FA BN wrote: ↑
02 Jul 2021, 07:24
Yeah, that's what was happening when I changed the pixel count.. different scroll speeds. (PG259QN @360Hz)
ms.potatoe wrote: ↑
05 Jul 2021, 15:22
960 ufo test bug (390Hz) is correct
ms.potatoe wrote: ↑
08 Jul 2021, 14:36
Videos were taken at 960 390Hz, slower than 960 360Hz.
Hopefully something can be done about this.
EDIT:
Just found out this isn't necessarily a bug. Could be due to integer or non-integer speeds at different refresh rates.
daviddave1
Re: Bugged UFO ghosting test speed at 390Hz
Post by daviddave1 » 17 Dec 2021, 04:29
Yesterday my 390Hz (Acer XV252QF) arrived.
Not sure if should test the VRB on 960 pixel per second or 1920
On 960 VRB is exaclty the same as on normal and extreme. On 1920 extreme wins: On normal the ufo windows are blurred.
What gives the best representation of a fast paced fps like quake champions, apex, valorant pubg? 960 pixel per second or 1920 pixel per second?
| Now: XG27AQNGV
Post by Chief Blur Buster » 21 Dec 2021, 01:56
daviddave1 wrote: ↑
17 Dec 2021, 04:29
It depends on your playing tactics -- do you scope-track or eye-track moving objects / while panning fast / etc?
Sometimes 1920 pixels per second is more realistic than 960 pixels per second.
