Glitch screen on XL2546K @240hz when signing out
Posted: 15 Jul 2021, 13:35
by phaze
Hey guys,
I just purchased the XL2546K and I realized something happens when I signout only @240hz, The screen glitches as shown here
https://imgur.com/a/xisGvtB
I reinstalled Windows, tried the combo for Restarting GPU (Ctrl + Shift + Win + B)
Tried Reinstalling GPU Drivers and trying old ones.
Still can't get to fix it.
Can't identify if its from the GPU or The monitor.
Re: Glitch screen on XL2546K @240hz when signing out
Posted: 15 Jul 2021, 18:07
by axaro1
I've tested two different XL254K units and neither of those two had the issue that you described.
It looks like a defect, what cable are you using?
Posted: 15 Jul 2021, 19:07
by phaze
axaro1 wrote: ↑
15 Jul 2021, 18:07
Display port the one that came with the monitor
Posted: 28 Jul 2021, 02:43
by phaze
Posted: 28 Jul 2021, 08:28
by RealNC
Check the monitor OSD to see if it switches refresh rate. If yes, then it's perfectly normal.
Posted: 28 Jul 2021, 11:01
by phaze
Nope, it doesnt change the Refresh rate.
