Is it true that GSYNC module monitors are forced to GPU scaling?
I know that the scaling function does not work if the in-game resolution and the window resolution are the same.
Is there any monitor that can select a display even for a recent GSYNC module monitor?
I know that the GPU scaling or display scaling feature doesn't work if I use "No Scaling" in the NVIDIA control panel.
Is that correct?
blackstorm82
- RealNC
Re: Is it true that GSYNC module monitors are forced to GPU scaling?
viewtopic.php?f=2&t=3269#p70066blackstorm82 wrote: ↑03 Aug 2021, 00:41Is it true that GSYNC module monitors are forced to GPU scaling?
