Nvidia Driver 471.96 Adresses high DPC issues
3xil3
Post by 3xil3 » 31 Aug 2021, 13:30
Just heads up aperantly nvidia driver causing high latency if display running at 8 bit which very common since most dispays use 8bit especally at higher refreshrates.
Ive been Been using and this does seem to help.
https://old.reddit.com/r/nvidia/comment ... iscussion/
https://www.nvidia.com/Download/Find.aspx?lang=en-us
edit
If anyone intested NVIDIA developer drivers 510.06 out just installed
https://old.reddit.com/r/nvidia/comment ... rcequadro/
so far so good with 510.06 BTW on windows 11 GPU power high perfromance with10900k/3080/240hz1440 and 8k mouse doom eternal 1440 150-240fps ive alt tab bunch times and swich fullscreen /windowed trying trigger higher DPC seem great so far Image
BTRY B 529th FA BN
Re: Nvidia Driver 471.96 Adresses high DPC issues
Post by BTRY B 529th FA BN » 31 Aug 2021, 14:37
Post by Chief Blur Buster » 31 Aug 2021, 15:51
Very interesting obscure latency issue -- thanks for relaying this.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 31 Aug 2021, 16:17
deama
Post by deama » 31 Aug 2021, 21:47
What was the issue to begin with? Why did it cause a high DPC and at what point would it?
Mugabi
Post by Mugabi » 01 Sep 2021, 03:36
Just download any 457 version
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 01 Sep 2021, 06:40
aerin
Post by aerin » 01 Sep 2021, 07:39
BTRY B 529th FA BN wrote: ↑
01 Sep 2021, 06:40
Mugabi wrote: ↑
01 Sep 2021, 03:36
Can you link any credible resources for this claim? Is there a database for DPC latency w/Nvidia drivers?
Thanks!
> Some apparent driver latency spikes are actually due to smi's in bios, which go unnoticed and show that random drivers are at fault, sometimes it hits the graphics driver. (... a bit out of context, but might be worth knowing)
3xil3
Post by 3xil3 » 01 Sep 2021, 09:15
Nevermind
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 01 Sep 2021, 09:15
