Good 1440p monitor with minimal ghosting/ invert ghosting/ blur?
Posted: 29 Sep 2021, 18:38
by maou42
Hi
I would like to purchase a new monitor for gaming.
Could someone recommend one with very little bluring/ ghosting/ overshoot?
I am not too fussed about the max refresh rate but I would love some G-Sync compatible panel.
Thank you
Re: Good 1440p monitor with minimal ghosting/ invert ghosting/ blur?
Posted: 30 Sep 2021, 00:45
by sk1p
Hi, Acer xb273ugx/ASUS XG27AQM/Asus PG279QM
I have Acer xv272ux(Freesync model) and really love this panel, TN clarity and no input lag, don't see there ghosting/blur or inverse ghosting, quality with the same panel should be little bit better with ASUS XG27AQM, but Acer has lower price.
Posted: 30 Sep 2021, 01:21
by Discorz
Posted: 30 Sep 2021, 11:13
by maou42
Thank you for the replies.
I had seen the list of suggested monitors but it does not lead to reviews and is therefore if limited use.
Posted: 30 Oct 2021, 14:50
by Handler
Asus PG279QM
LG 27GP850
Alienware AW2721D
Check Hardware Unboxed reviews on youtube, they test for this.
Posted: 31 Oct 2021, 21:55
by maou42
Handler wrote: ↑30 Oct 2021, 14:50
Asus PG279QM
LG 27GP850
Alienware AW2721D
Thanks. I got the LG 27GL850
Posted: 31 Oct 2021, 23:01
by Boomchakadah
Acer XV272U Kvbmiiprzx
Posted: 02 Nov 2021, 00:10
by maou42
Thanks but as I said, I have already bought the LG 27GL850 b
Very happy with it. Amazing monitor.
Posted: 02 Nov 2021, 03:15
by Boomchakadah
maou42 wrote: ↑02 Nov 2021, 00:10
That 170Hz Acer XV272U Kvbmiiprzx has less ghosting and better out of the box colors than your LG 27GL850
https://www.rtings.com/monitor/tools/co ... shold=0.10
Since you said that you're not too fussed about the refresh rate, I thought 170Hz would be enough. if you want a 240Hz 1440p, get the ASUS XG27AQM.
