tried 3 locations in 1 year, lag isnt gone
Mugabi
Post by Mugabi » 03 Oct 2021, 02:41
tried 3 apartments which are too far from each other in 1 year. the issue isnt fixed in all these locations, not a single difference, if u think changing location will fix your lag ur wrong my dear, u need to try mutiple pcs in mutiple locations using mutiple steam accounts with freshly windows reinstall using different isp's and then you might fix your lag. with that said,im gona try my bois nick's lag fix
viewtopic.php?f=24&t=9135&start=30
Anonymous768119
Re: tried 3 locations in 1 year, lag isnt gone
Post by Anonymous768119 » 03 Oct 2021, 06:19
demonstrate what kind of lag is it?
Mugabi
Post by Mugabi » 04 Oct 2021, 14:54
a_c_r_e_a_l wrote: ↑
03 Oct 2021, 06:19
In offline maps, mouse gets slower(u need to drag it , i end up increasing sensitivity but i still feel it getting really slow with mouse acceleration), hit registration issues (my bullets have a hard time connecting to enemy models, i can tell the difference when i reinstall windows, how bullets are supposed to connect and kill enemy faster), keyboard is slower, switching weapons/scoping with awp gets really slow, all of this leads to fatigue in my fingers after 4 minutes of tdm, it is actually that fucking bad.
In online maps (mm or faceit) these issue get much much much noticable. Changed location Hoping it would fix things but nothing changed, i suspect its my pc parts, the motherboard in precise is fucked due to living in a location with bad electricity
MegaMelmek
Post by MegaMelmek » 05 Oct 2021, 02:34
what is your PC setup? and what game you play?
Mugabi
Post by Mugabi » 05 Oct 2021, 04:33
MegaMelmek wrote: ↑
05 Oct 2021, 02:34
as if ur gona fix it
Eonds
Post by Eonds » 05 Oct 2021, 07:21
Mugabi wrote: ↑
03 Oct 2021, 02:41
Back at it again i see..... Have you checked your VRM thermals/configured bios? I know you said you tweaked bios but we both know you don't know what you're doing. I can help you if you let me. If you're going down the EMI rabbit hole at least order some ferrite chokes for your cords :|
Anonymous768119
Post by Anonymous768119 » 05 Oct 2021, 08:46
Can you record it? Your gameplay or anything? I've seen already guys with paranoid delusions claiming that their csgo works like a shit, but actually it was decent on the clip.
MegaMelmek
Post by MegaMelmek » 05 Oct 2021, 09:04
Mugabi wrote: ↑
05 Oct 2021, 04:33
MegaMelmek wrote: ↑
05 Oct 2021, 02:34
well if you play cs go there is some change that will not solve the input lag and suttering but make it way more enjoyable.
There is no point to say what i have done to fix this hard input lag on new PC.
I advice you get difrent mobo and new ssd thats all you need.The last that work for me is x570 asus rog strix f-gaming and new cheap ssd. I do belive that there is input lag building in time since you turn ON some PCs.
I am still on long way because i am on 3 days working PC wich i think is not much to say its fixed but that mouse feel in W10 on this mobo its insane and its not degrading. CS go is diffrent story if i run it in real time priority, mouse is perfect if in normal priority its kinda bad nearly same as on b550. For sure there is no need change hause or mouse or monitor or CPU becaise if you benchmark your cpu and it perform well its nothing wrog with it ond so on. CS Go is more complex it need fast internet fast cpu fast memory and so on at once and there is no benchmark like that. New mobo are not capable to do that all these sheets with latency are pointless if average plyer can see that there is something wrong with shot reg mouse latency and stuttering.
The reason i want to know your harware is that i can exclude it i my testing.
Mugabi
Post by Mugabi » 05 Oct 2021, 12:54
05 Oct 2021, 08:46
Yeah ofcourse im making all this shit up cuz im bad at cs
Mugabi
Post by Mugabi » 05 Oct 2021, 12:58
MegaMelmek wrote: ↑
05 Oct 2021, 09:04
Mugabi wrote: ↑
05 Oct 2021, 04:33
MegaMelmek wrote: ↑
05 Oct 2021, 02:34
Pc parts are not the issue, all are new.
Rtx 3070-5600x-b550 aorus elite ax- trident neo 16gb ram 3600mhz cl18-650w and 850w gold psus.
I suspect its my mobo m being faulty
