Question about Seiki 50"
Badstar
Post by Badstar » 02 Jun 2014, 10:44
Hello everyone, I am just about to purchase the Seiki 50" and my plan is to run it at 1080p@120hz.
How blurry would the screen be if I were to sit at around 3-4ft away? Is there a certain distance I have to be to fully enjoy the experience?
Any help/insight would be appreciated! Thanks!
Re: Question about Seiki 50"
Post by Chief Blur Buster » 02 Jun 2014, 18:05
Badstar wrote:Hello everyone, I am just about to purchase the Seiki 50" and my plan is to run it at 1080p@120hz.
The SEIKI 50" 4K HDTV doing 1080p true-120Hz looks pretty good from 4 feet away, that tends to be the sweet spot. It is not blurry at all from this viewing distance. Much closer than this, it does start to look blurry.
The sweet spot for 1080p gaming tends to be approximately 1:1 view distance (e.g. 4 feet away from a 50" display, or 2 feet away from a 24" monitor), this gives you similar angular density of pixels.
Waddo
Post by Waddo » 02 Jun 2014, 22:42
This is my favourite calculator for viewing distances and such although it hasn't been updated in a while it lets you edit everything in excel format...
http://carltonbale.com/home-theater/hom ... alculator/
if you have 20/20 vision then you can position your eyeballs up to 6.5 feet away but no less than 2.6 feet because of field of view but grainy fly-screen effect depends on the type of pixel formations/angles/filters etc. plus your brain might fry...
enjoy...
Post by Chief Blur Buster » 06 Jun 2014, 19:17
Thanks for the tip -- I've worked in the home theater industry, so I'm familiar with this.
Often, computer and gaming view distances tend to be different from television view distances. But it is all converging, with lots of computers and computer-like devices connected to TVs nowadays. Generally, 1:1 screen width viewing is common for computers -- e.g. approx 2 feet away from a 24" monitor, which doubles-up to approx 4 feet away from a 48" TV.
