English isn't my strong point but i ll try to explain as clearly as possible. Its not due to emi or radio or whatever interference. Its also not because of bad grounding. Primary cause is due to bad chipset/device initialisation due to voltage in neutral conductor. As you know we are getting single phase ac in our houses which contains phase(110/230V) and neutral(0V) which are ideal voltages. In reality we get like 2-15V in neutral which can be checked by using a multimeter between neutral and earth pins in your socket. If in your bad luck you are getting 40-60V in neutral wire then the circuit is completed via neutral and earth. Its gonna mess around with post operation while clearing nvram using cmos or jumper method. In order to properly initialise them or repair your pc or get rid of lag remove the psu wire and in fact all the devices including hdmi/dvi/vga/display/mouse/keyboard cables. Now we dont have anything connected to cpu. Now remove the case, remove gpu, and remove all ram if you have more than one. Clean one ram module and push it into one of the ram slot. Remove cmos battery and wait for 15-60 seconds and reconnect it. At this point not a single cable is connected while doing this. Now go ahead and connect power cable, keyboard and mouse. Now switch on cpu using power switch. Mash the delete button of the keyboard while its posting. You will get beep codes of no vga or no display. Let it complete the post operation and now switch off cpu using case power button. Now all your devices are completely reset. Now once again remove psu power cable and now populate the ram slots, push the gpu into pcie slot and connect all monitors and all the cables. After this all go ahead and connect psu power cable and switch on pc using case power button and voila your pc is now resolved of any initialisation problems. Thank you.
For someone, this will solve the problem temporarily.
the main reason for the input lag
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
