Best monitor for competitive FPS?
ditiy15447
Post by ditiy15447 » 23 Dec 2021, 11:54
looking for a monitor will be used for competitive fps so nothing really bothers besides ghosting and refresh rate etc
mainly playing apex, 3080 and 5900x so framerate is not a problem (though i think i'm supposed to cap 180 to avoid engine stutter)
very high budgest
upgrading from XL2430T
any suggestions?
EDIT:
after digging and reading, i'm torn between XL2546K and XG2431
to my understanding XG is better bang4buck and the difference between the two is negligible? i did try blur reduction (whatever was available back in 2015-2016) and the strobing gave me headaches but i still would like to give this a try
any advice what to go with? again, budget is no problem, looking for the best of the best
ditiy15447
Re: Best monitor for competitive FPS?
Post by ditiy15447 » 23 Dec 2021, 21:34
