nuk_won wrote: ↑29 Dec 2021, 05:17
Thatweirdinputlag wrote: ↑28 Dec 2021, 13:29
nuk_won wrote: ↑26 Dec 2021, 13:22
latency mon shows that kernal timer latency is high but doesnt say how to fix it.i get 10-50ms frametime spikes in all games online/singleplayer. most of them are when going in a new area or loading level or a granade goes off generated by sound. ive tried a lot of things bios tweaks. fresh instals windows 10/11. tried optimizations etc. overclock/undervoltage.smt on off. xpm on off. bios game mode on off.c states disabled. ultimate powerplan others deleted.all drivers up to date. amd chipset drivers tried unnistaling them tried without them no change.when the stutter happens the gpu sage goes to 0% a spike in cpu usage and frame time jumps to 10-50ms i get a visual stutter sound cut out and then everthing goes back to normal. ive changed ssd. psu. ram. gpu. built pc outside the case. disconected usb devices. been batteling this for months now. maybe its just a cpu bottlenck that im facing here? any help or idea how to fix this would be nice thx.
cpu; ryzen 5 3600
gpu: 1080ti strix
ram: gskil trident z 3200mzh cl14
ssd: 1t 980 m.2
mb: b450m mortar max
psu: rm850x
temps undear load doesnt go over 60c
Hello nuk_won,
If you're really interested in getting your Kernel latency down to 1ms try to download an application called DPC Latency Checker V1.4.0, for some reason that was the only application that I found to force the kernel latency timer down to around the 1ms mark, with timer resolution I was able to force it even lower, hovering around the 0.05-0.15ms latency mark. But I don't think that I noticed anything changing to the extent of my being super hyped about it or to keep it on all the time.
The application does not even need to be running btw, just open it and watch your Kernel Timer go down
! Why this application in specific? I have no idea, but if I had to guess, maybe it forces the system into some sort of a sensitive low latency mode state.
I also attached a picture that shows how the kernel timer would be with the application on + ISLC Timer Resolution set to 0.51! Also worth to mention that I had Microsoft edge with 8 tabs, Riots Client, Valorant Game, G Skill Trident and my audio interface app all running in the background.
Hope it helps you out mate! Let me know
i download the DPC. i got them down but i know u are not suposted to run ion while gaming. i lunched the game and every time when there is a spike in game the DPC registers thaat and i dont know what is causing that
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!THIS WAS WHILE PLAYING A GAME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:23:19 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: NUK_WON
OS version: Windows 11, 10.0, version 2009, build: 22000 (x64)
Hardware: MS-7B89, Micro-Star International Co., Ltd.
BIOS: 2.E3
CPU: AuthenticAMD AMD Ryzen 5 3600 6-Core Processor
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 16309 MB total
CPU SPEED
Reported CPU speed (WMI): 280 MHz
Reported CPU speed (registry): 360 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED KERNEL TIMER LATENCIES
This value represents the maximum measured latency of a perodically scheduled kernel timer.
Highest measured kernel timer latency (µs): 12589.0
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 12.910
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001663
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.001663
ISR count (execution time <250 µs): 192350
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 9646.570
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 497.29 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.096118
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 497.29 , NVIDIA Corporation
Total time spent in DPCs (%) 0.237731
DPC count (execution time <250 µs): 4686745
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 8
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 172
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: steam.exe
Total number of hard pagefaults 112697
Hard pagefault count of hardest hit process: 57712
Number of processes hit: 76
PER CPU DATA
CPU 0 Interrupt cycle time (s): 45.002586
CPU 0 ISR highest execution time (µs): 0.0
CPU 0 ISR total execution time (s): 0.0
CPU 0 ISR count: 0
CPU 0 DPC highest execution time (µs): 9646.570
CPU 0 DPC total execution time (s): 4.127841
CPU 0 DPC count: 2119888
CPU 1 Interrupt cycle time (s): 4.042989
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 263.330
CPU 1 DPC total execution time (s): 0.169817
CPU 1 DPC count: 73586
CPU 2 Interrupt cycle time (s): 4.805262
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 262.460
CPU 2 DPC total execution time (s): 0.337760
CPU 2 DPC count: 138884
CPU 3 Interrupt cycle time (s): 4.310774
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 261.990
CPU 3 DPC total execution time (s): 0.162498
CPU 3 DPC count: 69808
CPU 4 Interrupt cycle time (s): 39.432189
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 267.210
CPU 4 DPC total execution time (s): 10.391425
CPU 4 DPC count: 646964
CPU 5 Interrupt cycle time (s): 65.063083
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 308.490
CPU 5 DPC total execution time (s): 19.596712
CPU 5 DPC count: 1172830
CPU 6 Interrupt cycle time (s): 5.973776
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 197.640
CPU 6 DPC total execution time (s): 0.205412
CPU 6 DPC count: 59842
CPU 7 Interrupt cycle time (s): 5.254133
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 94.330
CPU 7 DPC total execution time (s): 0.085847
CPU 7 DPC count: 28256
CPU 8 Interrupt cycle time (s): 15.739154
CPU 8 ISR highest execution time (µs): 12.910
CPU 8 ISR total execution time (s): 0.235028
CPU 8 ISR count: 167085
CPU 8 DPC highest execution time (µs): 130.130
CPU 8 DPC total execution time (s): 3.701164
CPU 8 DPC count: 227878
CPU 9 Interrupt cycle time (s): 8.330370
CPU 9 ISR highest execution time (µs): 10.720
CPU 9 ISR total execution time (s): 0.044386
CPU 9 ISR count: 25265
CPU 9 DPC highest execution time (µs): 107.70
CPU 9 DPC total execution time (s): 0.686464
CPU 9 DPC count: 62661
CPU 10 Interrupt cycle time (s): 5.932027
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 248.880
CPU 10 DPC total execution time (s): 0.165602
CPU 10 DPC count: 43944
CPU 11 Interrupt cycle time (s): 6.034973
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 248.970
CPU 11 DPC total execution time (s): 0.301127
CPU 11 DPC count: 42384
