is lmb technonlogie better than DyAc? or can I use the blur buster utility plus DyAc to generate the same good lmb as the xg2431
if I set the xg2431 to a good bright level, is it better than DyAc there?
can I set the xg2431 to a certain HZ number with lmb like 180hz with lmb or only 60/120/240 and can i do this with the Benq to?
if i play with DyAc and my fps drop to 180fps is it still playable is it the same on the xg2431 or could i get more ghosting with the monitor than with dyac?
and it can be that I perform worse with 23.8 inches than with 24.5 because of the pixel density
I don't know if that's a stupid question but is there a certain reason why the Benq Zowie XL2546K costs € 200 more than the xg2431 or is that just one thing that you buy the brand
I hope I get an answer to the many questions I have. It would help me a lot with my purchase decision
