BREAKTHROUGH: Hand-waved iPhone 13 pursuit camera outperforms rails for rapid field testing
Post by Chief Blur Buster » 05 May 2022, 17:45
Chapter 2
If you have not read chapter 1, please see New Easy Rail-Free Pursuit Camera Technique first before reading this.
Hobbyist Pursuit Camera Without Rails Sometimes Outperform Some Reviewers
An addendum to the older article, New Easy Rail-Free Pursuit Camera Technique, that some hobbyists are doing at home and sharing pursuit images.
Handwave Smartphones Now Outperform Rails for Field Testing
After collecting data for 5 years, we have discovered that amazingly, handwave pursuit camera can sometimes outperform “less-than-high-end” field rail setups.
An expert permanent headquarters rail will always outperform hand-waves, but field testing often use tripods that are shaky and too lightweight, e.g. capturing pursuit photos of a display at a convention or at a store (like Best Buy).
Pursuit Camera Rail Problems For Rapid Field Testing
- Shaky light tripods
- Carpets at convention floors
- Heavy camera that flexes cheap travel-friendly camera rails
- Some conventions won't let you enter with large metal objects (security).
- Rail vibrations while camera slides on cheap lightweight rails
- Only few photo attempts are possible in 5 minutes
- You have to "fight" the camera settings sometimes.
Handwave Smartphone Advantages For Rapid Field Testing
- 4K Video as burstshoot substitute (1000+ photographs in 30 seconds)
- Custom apps can be downloaded
- Brute-force thousands of photographs compensates for error of hand-shaky
- Easy to jog-shuttle forward/back in video players to find the good photos
- TestUFO "Sync Track" invention is almost as good as a defacto a cryptographic certificate of hand tracking accuracy
- Much less setup/teardown required
Why good practiced iPhone/Galaxy handwaves now outperform rapidly-setup field rail builds
- Field testing requires rapid setup and teardown.
- Sometimes tripods have to be put into a carpet in a convention.
- Sometimes a SLR camera is too heavy for a lightweight mobile camera rail.
- Cheap lightweight camera rail flexes and vibrates a lot.
- Cheap tripods flexes too much.
- Easier media management of originals; one video file instead of a pollution of unusable burstshoot JPGs
- No time to validate a field build of a camera rail (convention, TV store, prototype)
- Handwave smartphone means no airline baggage, no carryons needed! Travel to conventions like CES/DisplayWeek/Computex/CEDIA/etc via ultra low fare airlines like RyanAir, Swoop, AlaskaAir, etc!
New 8K Phones Do Excellent 4K Video Almost SLR Quality Per Freezeframe
- 30fps video burst-shoots 1800 photographs per minute (brute-force your way out of shaky hand error margin)
- 60fps video burst-shoots 3600 photographs per minute (brute-force your way out of shaky hand error margin)
- Phone technology has now improved massively as of year 2022
- Some phones have amazing excellent image stabilization that does not affect freezeframe quality
- Camera apps on iPhone such as DSLRCamera or ProCam that turns video into a manual burst-shoot emulator
- Some new phones can do ProRes video, at better quality per freezframe than JPG files of a 3-year-old phone.
Many TestUFO tests have Dual Pursuit Tracks!
Make sure both the top/bottom pursuit sync tracks are perfect, when doing handwaves.
Sometimes the hand rotates when pursuiting, so that means either the top/bottom sync tracks will go "bad" because one edge of the photo went at a different speed. That's exactly why I use multiple sync tracks; for compatibility with handwave pursuits.
IMPORTANT: If you do the computer-chair-spin technique, make sure you back up enough that the smartphone is roughly the same distance from the monitor, as your original pursuit camera rail or your viewing distance. This is important because a camera too close to the screen will amplify viewing angle problems (e.g. TN and VA viewing angle gamma problem). There's enough brute resolution in a 50 megapixel sensor to use a light amount of zoom, from a further viewing distance instead; that is what I recommend. Use a LOT of zoom initially during practicing so you can watch the screen while you're holding the phone landscape with two stiff shoulders + stiff outstretched hands from your spinning computer chair. Most get fairly good after about 15 minutes of practice with a modern 4K optically-stabilized smartphone with lots of megapixels + good light capability. That's very little training time for a human, even if confusing at first.
Handwave Professionals Now Reporting 0.1 Pixel Error Margins Now!
A few years ago, handwaved smartphones were achieving 0.25 pixel error margins.
Two years ago, cheaper phones did this:
This already finally matched the rail quality of a mid-range field test rail-based pursuit camera rig with its cons listed above.
Today, with newer 8K optical-stabilized smartphones (iPhone 13) but using downconverted high-bitrate 4K settings to its high speed SSD-quality flash memory...
It is now possible to get 0.1 pixel error margin with handwaves, perhaps less, on some newer 8K-capable smartphones running at its conservative 4K settings for near-SLR-quality per freezeframe. Apparently, its optical image stabilization responds fast enough to sometimes do a near-perfect pursuit greatly compensating for the error margins of a shaky hands.
This exceeds rail-quality for field rigs!
Discorz
VIP Member
Re: BREAKTHROUGH: Hand-waved iPhone 13 pursuit camera outperforms rails for rapid field testing
Post by Discorz » 06 May 2022, 14:23
Lovin' it. Its amazing what can be captured with these days phones.
These two are best hand-waved photos I could get with my smartphone. Took many attempts.
Gigabyte M32Q @170Hz, 170 FPS
Aim Stabilizer Sync at middle screen
Overdrive Balance
960 pps
Xiaomi Redmi Note 9S camera, photo mode, no stabilization
Post by Chief Blur Buster » 06 May 2022, 14:45
Discorz wrote: ↑
06 May 2022, 14:23
Good attempt!
Even though this is not as SLR-quality as an iPhone 13:
I find that the iPhone 13 is much better though, it doesn't show any camera-artifacts (like horizontal bars or photo curving), and the optical stabilization helps noticeably.
Also, incredibly, in one of the two attempts, you achieved roughly ~0.1 pixel hand-tracking accuracy with that old phone:
Zoomed version:
I've actually managed to also do exactly the same thing with strobed displays (which are challenging to perfectly handwave). iPhone 13+ really helped since the optical stabilization really helped increase my success rate.
Given sufficient attempts, guess you don't need an iPhone 13 optical stabilization to handwave that accurately, thanks to the bruteforce spray of video frames, giving many "chances" of chance-accuracies in your handwave pan.
As you swung as moving smartphone sideways, you even captured 4 refresh cycles' worth of screendoor artifact darn nearly perfectly on top of each other -- preserving the screendoor artifact on a camera exposure of 4 refresh cycles long!
I even rarely see rail-based pursuits this accurate (from a sync-track perspective). The chief problem with your (probably cheap) smartphone camera is the camera artifacts (bowing, fisheye, horizontal lines), but that's simply fixed by newer superior smartphone cameras, combined with optical image stabilization. Which are much easier in fewer attempts.
It just continues to prove my point: You don't always need a rail anymore for high-quality indie pursuit camera tests.
That being said, reviewers and professional testers will need a good higher end smartphone camera (e.g. iPhone 13) to check all boxes (no camera artifacts). But your attempt is great for indie/forum member sharing.
TFTCentral is already using the railless method, AFAIK.
Discorz
VIP Member
Post by Discorz » 14 May 2022, 06:12
Just tried to improve. Used less fisheyey photo mode with compromise of lower resolution, zoomed in a bit to trim some of the image distortion, still no stabilization but this time with random DIY "rail" made out of glued guides on top of wooden panel which helped with horizontal tracking but not as much with vertical. I reduced refresh rate to 120 Hz for perfect shutter-refresh match to remove flicker banding. Tracking accuracy is still very similar, perhaps a hair better on previous attempts.
Gigabyte M32Q @120Hz 120 FPS
Aim Stabilizer at middle screen
Overdrive Picture Quality
960 pps
EXIF included
Measured persistence from image approx. 1.2-1.4 ms
Post by Chief Blur Buster » 17 May 2022, 19:40
That's pretty good.
We're both doing it spectacularly reliably!
I also used makeshift wooden rails in many of my early pursuit camera experiments ten years ago. I used scotch tape to make surfaces more slippery and easier to slide on without vibrations, though the tape became rough after about 100 pursuits and had to be repeatedly replaced.
Very ghetto jerryrigged setups until I purchased a sliding camera rail from Amazon that performed better (as long as vise-mounted on top of stiff wood, rather than on wobbly tripods).
I'm amazed how many reviewers use wobbly tripods on carpet, and I can outperform them with an optical-stabilized-camera iPhone 13 handwave!
Post by Chief Blur Buster » 29 Oct 2022, 01:26
Future: Automatic Smartphone Pursuit Camera App With Automatic GtG Graphing!
Long-term, I want to make a smartphone app that measures pursuit camera images & also doubles as a photodiode oscilloscope (up to 10,000 samples/sec). I've already discovered it is mathematically possible on modern camera sensors now, on all recent iPhone/Galaxy phones.
User Experience
1. A user just waves a camera
2. Camera goes beep
3. Resulting perfect pursuit image + LCD GtG graph!
Behind-The-Scene Algorithm
1. The camera is continuously recording in video mode at automatically preset settings (just like this thread)
2. A neural network AI built into the app will recognize the sync track (pretrained on known good/bad sync track results -- probably a single video file containing hundreds of handwaves is actually adequate training material for a starter app)
3. The app will pay attention to the sync track until it manages to capture a perfect freezeframe within desired error margin
4. The freezeframe is saved. That becomes the officially saved pursuit camera image.
5. To extract LCD GtG, you simply take a pixel row from the camera image (of a moving edge -- you could key on a single tickmark, or I can modify the sync track to include a built-in moving edge convenient for LCD GtG measurements), and subtract perfect linear straight-line MPRT100% from it. Anything leftover is LCD GtG identical to a photodiode oscilloscope!
6. Display resulting photo & display resulting GtG graph (like a photodiode oscilloscope).
A software developer can even use multiple pixel rows in resulting photograph, scanskew-correct it (based on moving-blur-edge tilt in photograph) and challenge the user to zoom in closer with faster pans, to spread more motionblur onto the camera sensor over a single refresh cycle, to get more "photodiode oscilloscope sample rate equivalent". I was able to determine that current smartphone sensors in iPhone 10-13 is now accurate enough to become a 10,000 samples/sec GtG photodiode oscilloscope, via the automated pursuit camera trick above.
And GtG heatmapping could be done on the same photo (simply by displaying multiple moving blur-edges of different color pairs). Heatmap 25 LCD GtGs in one pursuit photograph! As long as the blur edge can be blurred significantly across the horizontal resolution of the photo. Say, the blur edge is spread over about 10% the photograph width, and has an accurate sync track to 1 photography pixel, then a 4000 pixel-wide photo essentially has 400 photodiode oscilloscope samples per refresh cycle. At 144Hz, that's 144*400 = equivalent to a photodiode oscilloscope doing 57,600 samples/sec. Obviously bayer filtering, camera tracking error, lens blur, and image scaling adds error margins, but I am underscaling to 4000x3000 get a tack sharp photo, and from that you can get 5-digit samples/sec photodiode oscilloscope data from a single 1/30sec 4000-pixel-wide photograph!!! Amazing how math can pull this off. And you can get better than 16-bit accuracy (like a good Tektronix oscilloscope) simply by averaging/stacking multiple pixel rows from the photograph -- that's a 3000 pixel tall photograph, representing defacto 3000 separate unique runs of a photodiode oscilloscope to be averaged (stacked) on each other. You'd have to skew-correct the photograph (a simple math matter, since we know all pixel rows represents the same GtG run attempt), but then:
Theoretically iPhone 13 can be translated to a ~10,000 samples/sec 16-bit GtG photodiode oscillscope!
(with these algorithms above).
All it requires would be a custom TestUFO motion test, the only thing an end user does is keep hand-waving along the UFOs until the smartphone until the app goes beep, then the math magic pulls a clean GtG oscilloscope curve from a single camera image!
Amazingly, it appears mathematically clear that an iPhone 13 camera can outperform a single-run low-samplerate oscilloscope on an op-amp'd photodiode (albiet only for display measurements)! Once you've done all the math tricks above.
You could pursuit-photograph multiple moving blur-edges simultaneously of different color-pairs. Then LCD GtG heatmapping is just an app that any user can download! (a GtG matrix measurement from a SINGLE pursuit camera photo).
You're welcome. I believe I'm the world first person to suggest this "iPhone GtG photodiode oscillcope" idea for GtG graphing automatically. Please credit me for the free idea. (And don't patent it, thank you.) Researchers, contact me if you'd like to open-source collaborate on this idea -- www.blurbusters.com/contact
Post by Chief Blur Buster » 26 Sep 2024, 20:36
Crossposting:
The new iPhone 16 with 4K 120fps HFR video is perfect for tripodless handwave pursuits.
You can even attach an SSD thumbdrive (1GB/sec) to the iPhone 16 USB-C port, for uncompressed 4K 120fps video!
Although I have a mirrorless Sony Alpha a6000 camera I use for rail-based pursuits, my iPhone 14 Plus outperforms most tripod-based pursuit cameras now, because of these factors, where shaky tripods, slide vibrations, and flexible rails can create error margins bigger than 5 minutes of handwave pursuits by 10,000-freezeframe bruteforce (scroll through video slider, find clearest freezeframe, save freezeframe). Good heavy rails and high-end sliders will outperform, but my handwaves outperform 90% of reviewers.
So, get a good rail-based setup, or just don't bother and practice high-quality handwaves, whether a phone or a discrete camera. The sync track is the photographic proof of tracking accuracy, so it doesn't matter however you pursuit it.
01 Apr 2020, 00:19
Here are improved instructions that works with many "Professional Camera" apps in Google Play and iPhone App Store. Such as "DSLRCamera" on iPhone.
Setting Up Your Smartphone For Easy Hand-Wave Video Pursuit Camera
  1. Go to Google Play or iTunes on your smartphone
  2. Download and install a high-rated professional SLR-like Camera App that allows you to do manual-everything during video
  3. Run www.testufo.com/ghosting
  4. Configure video camera app to FIXED EXPOSURE (Prefer 4 refresh cycles, i.e. 1/30sec 30fps for 120Hz)
  5. Configure video camera app to FIXED COLOR TEMPERATURE (6500K)
  6. Configure video camera app to FIXED FOCUS (with phone arm's length away from monitor)
  7. Configure video camera app to ISO to brighten as needed. If too dark/noisy or bright/overexposed, brighten or darken monitor brightness setting if you want to save time fiddling or if your camera app has no ISO setting.
  8. IMPORTANT: Do not bring camera too close to the monitor (blurry) -- back away slightly and use a little bit of zoom (sharper). Most phones don't macro very well without using the backaway-and-zoom trick. Due to phone resolution, backing to arm's length may not be practical, but please use minimum 6" or 15cm, preferably at least 12" or 30cm. Your pursuit camera will be more accurate if you use more similar camera-distance as eye-viewing distance. Focus will be about 10x+ sharper than bringing phone too close to screen.
  9. Finally, configure video camera app to a BRIGHTNESS or ISO SETTING that doesn't underexpose/overexpose per frame.
    (Note: Framerate doesn't matter as much as ability to adjust camera exposure per frame, you may have to configure the camera frame rate in order for it to let you adjust the exposure settings the way you want it. Also, not all camera video recording apps lets you configure everything, so you may have to experiment with different apps until the app lets you correctly configure the video settings).
  10. Start video recording. (Note if image is too bright or too dark,
  11. Hand wave the video a few times just like the YouTube video embed, from about arm's length away
  12. If you need more steadiness, try stiffening your arm, holding phone with both arms and swivel your computer chair instead
  13. Afterwards, play the video using a good single-frame-stepping player app (if using smartphone, use a video player app that has a touchscreen jog slider, combined with PREV/NEXT framestep buttons) to find the clearest freezeframe.
  14. You've found your good smartphone hand-pursuit photo (simply buy using video as an equivalent of photo-burst-shooting to maximize odds of a good pursuit photograph). Save the freeze frame as a photo. This becomes your good pursuit photo.
  15. Done!
(The video file can be kept, it can be quite educational showing people how a pursuit camera works -- the video file shows self explanatory behaviours -- it instantly tells the users that camera tracking is the same thing as eye tracking -- where tickmarks looks bad until the camera goes at the same speed as the UFOs -- just as if you did WYSIWYG).
I have updated and improved the instructions.
This is the technique I used to get this OLED 480Hz freezeframe:
https://twitter.com/BlurBusters/status/ ... 5006037266
