TAA also makes games super blurry & its starting to be forced.
lextra2
Re: TAA also makes games super blurry & its starting to be forced.
Post by lextra2 » 16 Jan 2024, 09:32
You can adjust the TAA sharpness in unreal engine 4/5 games by adjusting
Code: Select all
r.TemporalAACurrentFrameWeight=0.04
Inside engine.ini (check pcgamingwiki for exact filepath)
By default it is set to 0.04 which is pretty low. Increasing it to lets say 0.08 makes it twices as sharp. Try it yourself.
