Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
bwainzz
Post
by bwainzz » 29 May 2024, 10:08
cursed-gamer wrote: β29 May 2024, 10:02
bwainzz wrote: β29 May 2024, 09:03
look at this game, so clean and smooth
we are cursed
It's hilarious how he holds the corners. Just like he is playing against bots. For me it is impossible because it equals insta hit in my face. I had to adjust my gamestyle and be sweaty as fuck to be somehow useful.
And what really funny is, he is not even that good. His hits just land and that's it.
It's amazing how the game works in a way for some people, I would never be able to hit those 3 deagle taps on the mirage window, this guy's enemies move in slow motion
Watching donk streams and some top faceit rankings and then playing a match is discouraging, it feels like another game
cursed-gamer
Post
by cursed-gamer » 29 May 2024, 10:14
bwainzz wrote: β29 May 2024, 10:08
That's why I bet the cause is the Internet connection. Some fucked up ISPs just can't handle the traffic or see UDP as a flood.
bwainzz
Post
by bwainzz » 29 May 2024, 10:20
cursed-gamer wrote: β29 May 2024, 10:14
Have you tried playing via WiFi? or some adjustment that had some influence on the ethernet connection without being a placebo?
dervu
Post
by dervu » 29 May 2024, 10:29
You know this is easily disprovable with your own server and something like iperf.
cursed-gamer
Post
by cursed-gamer » 29 May 2024, 10:32
bwainzz wrote: β29 May 2024, 10:20
I have this shit since around 2008. I stopped with any kind of tweaks/new pc parts etc. Nothing gave me even slight difference. It just stays with me for whatever reason. The only difference I feel is when I don't play on my PC.
cursed-gamer
Post
by cursed-gamer » 29 May 2024, 10:33
dervu wrote: β29 May 2024, 10:29
It's not, you can't check the UDP latency because you need perfectly synchronized clocks on both ends.
JimCarry
Post
by JimCarry » 29 May 2024, 13:21
bwainzz wrote: β28 May 2024, 16:55
my game has input delay: the screen melts
360hz/400+fps
I think your problem is resolution timings,i use CRU and put custom timings and make my monitor scaling.If you want to know if your monitor is scaling you find it by doing this,When you are in game your monitor should show your resolution i will give example i have acer 240hz and i play 640x480 fullscreen,monitor scaling with CRU.
The second pic is my cru custom timings,and then picture in real life on the monitor IN GAME showing my resolution and that means its monitor scaling,because if i did not use CRU its show my native resolution and that mean its gpu scaling,Also the first picture is a random guys custom timings with 360hz maybe you copy pastem and see if there is difference.
- cru 360hz.GIF (183.53 KiB) Viewed 9737 times
- cru.GIF (253.97 KiB) Viewed 9737 times
JimCarry on 29 May 2024, 16:04, edited 1 time in total.
dervu
Post
by dervu » 29 May 2024, 13:26
cursed-gamer wrote: β29 May 2024, 10:33
It is, just buy atomic clock PCI-E card for server and client.
bwainzz
Post
by bwainzz » 29 May 2024, 13:30
JimCarry wrote: β29 May 2024, 13:21
360hz/400+fps
The second t pic is my cru custom timings,and then picture in real life on the monitor IN GAME showing my resolution and that means its monitor scaling,because if i did not use CRU its show my native resolution and that mean its gpu scaling,Also the first picture is a random guys custom timings with 360hz maybe you copy pastem and see if there is difference.
Could you tell me exactly how I can do this brother? I play CS at 1280x960 resolution
JimCarry
Post
by JimCarry » 29 May 2024, 13:37
bwainzz wrote: β29 May 2024, 13:30
360hz/400+fps
Brother i will show you a video but you must be very carefull some monitors dont have monitor scaling.
so there is 3 million guides on youtube how to use CRU
https://www.youtube.com/results?search_ ... y+scaling+
but i use the most basic way:First i open extension block and find highest refresh rate resolution then i click "copy",i paste it in detailed resotlion from then, i adjust wich resotlion i will use. in your case 1280x960 and then,i edit custom timing.You can just do everything without custom timings and copy the settings on the screen i provide.after that pres restat64.It is proven that monitor scaling is better and faster.and i can feel the diffrence streched resolution on my monitor scaling is fast as f@ck.
Also if you want to know if it works,go in game press on the buttons on the monitor is show your 1280x960 and your refresh rate then it works.if your show your native it does not.Pretty much just see the post that i wrote.
- custom.GIF (212.75 KiB) Viewed 9710 times
