TPM 2.0 is a absolu disaster [Faceit players]
Riggedinho
Re: TPM 2.0 is a absolu disaster [Faceit players]
Post by Riggedinho » 08 Jun 2024, 12:39
@JimCarry
hmmm it's very strange that Faceit doesn't force you to activate it since then. I can see from your screenshot that Faceit only asks you to activate TPM (although you can override this after clicking ok) and to update Windows, it doesn't ask you to activate Secure Boot (certainly activated in your bios).
In your case, an external TMP module (if your motherboard has a slot for it) doesn't seem necessary, since you can play on this platform without TPM.
JimCarry
Post by JimCarry » 08 Jun 2024, 13:46
Riggedinho wrote:
08 Jun 2024, 12:39
@JimCarry
"hmmm it's very strange that Faceit doesn't force you to activate it since then."
Brother my friend plays since 2013 ,his acc is from 2013 and last night,he start face it anti cheat and it says that if you wish to play you must enable tpm,and secure boot,he told me he did only this: "https://www.youtube.com/watch?v=0rFrgPT1O9s
"In your case, an external TMP module (if your motherboard has a slot for it) doesn't seem necessary, since you can play on this platform without TPM."
Yes you are right,but i think its because i am too low level right now i am 6 i was 8.maybe when you start to reach last levels face it force you to use it,anyway can you tell me how to know if my mother boards supports this shit,also how to install it and last where to find it(if the site you provide does not have it or the money for shiping are the price of the module.
Riggedinho
Post by Riggedinho » 08 Jun 2024, 13:48
I would not take a video because I do not know how to record on the computer (as an indication for the Faceit evidence of reporting I record with my cell phone and the image is horrible) I would therefore take different screenshots of the framerates in the game in fps_max 300 and fps_max 0, MS stability as well as LatencyMon.
I will do this in the evening
Riggedinho
Post by Riggedinho » 08 Jun 2024, 17:50
So here are the different screenshots concerning the benefits of my external TPM module with details:
On LatencyMon I am below 1 regarding the average measured interrupt to DPL latency while my bios is by default with C-State, speedshift, hyperthreading and also I play in audio jack so HD audio is also activated.
Whereas before without the module I was around 1.20.
Also as you can see I remain in the green regarding the curve
Riggedinho
Post by Riggedinho » 08 Jun 2024, 17:51
On MouseTester a rather straight line (once again despite my default bios) with a very correct survey.
Before it wasn't so clean.
Riggedinho
On the benchmark test I gained around twenty fps but the most important thing is the stability of the framerate (I play in native resolution 1920x1080 with an i5 13600KF and an RTX 3060) if I lower the resolution it has to be 4/3 I am on average at 600 fps.
Riggedinho
Post by Riggedinho » 08 Jun 2024, 17:52
For the screenshots in the game it's Faceit games at the spawn at the start of the round (I cap my fps at 300 compared to my configuration) and you will note that the fps are blocked at 300 and that the ms is low . When I am moving they do not go below 290 in these waters which allows me to keep a low ms.
Whereas before it was crazy fluctuations, a real roller coaster, it went from 3 to 5 or 6 all at once.
Riggedinho
Anyway, the fact that TPM creates crazy latency on systems is no longer an urban legend
F1zus
Post by F1zus » 08 Jun 2024, 21:38
Riggedinho wrote:
08 Jun 2024, 17:52
Obviously TPM is garbage on gaming systems, as is Security Boot, Global C-State. All of these security features impose huge latency and should not be used on gaming systems. Let them be used in corporate versions of Windows. I'm sure windows copilot is also garbage, just like game bar.
Microsoft should release a gaming version of the operating system without this garbage.
Unreazz
Post by Unreazz » 09 Jun 2024, 04:59
Don't know about this, since im on windows 10 and checked on this. on my mb its deactivated and you don't need it everywhere. Valorant as example required it for Windows 11 users but not for 10 so i can't really argue about that
