Fix for input lag
Re: Fix for input lag
Post by Slender » 16 Sep 2024, 20:17
Mugabi wrote:
16 Sep 2024, 17:37
When will u guys understand that lag is coming from u
Yes. Of course.
issawm
Post by issawm » 17 Sep 2024, 06:54
Slender wrote:
16 Sep 2024, 12:33
issawm wrote:
16 Sep 2024, 02:56
OK so update: i bought a $200 APC UPS and it worked for 2 days now it isnt bro im going insane rn
bad grounding
what makes u say that im not tryna insult ur intelligence i just wanna know why u think that :)
Post by Slender » 17 Sep 2024, 07:03
issawm wrote:
17 Sep 2024, 06:54
Slender wrote:
16 Sep 2024, 12:33
issawm wrote:
16 Sep 2024, 02:56
bad grounding
ups can't filter interference.
for 100% work this device need good ground.
that UPS make a lot of interference, that a reason why pc work same from battery, and why it stop "working" after 1-2 days.
ablemor
Post by ablemor » 17 Sep 2024, 07:45
How to filter interference
Post by Slender » 17 Sep 2024, 10:52
ablemor wrote:
17 Sep 2024, 07:45
IDK. need to fix grounding in your house or buy good filter conditioner.
maybe UPS with double conv. + filter can fix all.
issawm
Post by issawm » 17 Sep 2024, 16:53
Slender wrote:
17 Sep 2024, 07:03
issawm wrote:
17 Sep 2024, 06:54
Slender wrote:
16 Sep 2024, 12:33
issawm wrote:
16 Sep 2024, 02:56
bad grounding
oh im not using the battery i just have it plugged into the outlet and its been a lot better but not 100%
ablemor
Post by ablemor » 18 Sep 2024, 05:32
so no power strip, just outlet?
issawm
Post by issawm » 18 Sep 2024, 07:00
ablemor wrote:
18 Sep 2024, 05:32
so its the APC UPS and it comes with 10 outlets. but the battery only kicks off when its not connected to the outlet on the wall. i have it plugged into the wall at all times
skkiNN
Post by skkiNN » 18 Sep 2024, 11:23
Have someone tried this filter and knows how to install it in our homes?
https://www.comestero.shop/shop/filtri- ... ZjEALw_wcB
issawm
Post by issawm » 26 Sep 2024, 23:21
i also remembered my cousin came over my house and his pc setup was working correctly and mine wasnt thats what leads me to believe it isnt electrically related
