Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Post
by Slender » 16 Sep 2024, 20:17
Mugabi wrote: ↑16 Sep 2024, 17:37
When will u guys understand that lag is coming from u
Yes. Of course.
issawm
Post
by issawm » 17 Sep 2024, 06:54
Slender wrote: ↑16 Sep 2024, 12:33
issawm wrote: ↑16 Sep 2024, 02:56
OK so update: i bought a $200 APC UPS and it worked for 2 days now it isnt bro im going insane rn
bad grounding
what makes u say that im not tryna insult ur intelligence i just wanna know why u think that
Post
by Slender » 17 Sep 2024, 07:03
issawm wrote: ↑17 Sep 2024, 06:54
bad grounding
ups can't filter interference.
for 100% work this device need good ground.
that UPS make a lot of interference, that a reason why pc work same from battery, and why it stop "working" after 1-2 days.
ablemor
Post
by ablemor » 17 Sep 2024, 07:45
How to filter interference
Post
by Slender » 17 Sep 2024, 10:52
ablemor wrote: ↑17 Sep 2024, 07:45
IDK. need to fix grounding in your house or buy good filter conditioner.
maybe UPS with double conv. + filter can fix all.
issawm
Post
by issawm » 17 Sep 2024, 16:53
Slender wrote: ↑17 Sep 2024, 07:03
bad grounding
oh im not using the battery i just have it plugged into the outlet and its been a lot better but not 100%
ablemor
Post
by ablemor » 18 Sep 2024, 05:32
so no power strip, just outlet?
issawm
Post
by issawm » 18 Sep 2024, 07:00
ablemor wrote: ↑18 Sep 2024, 05:32
so its the APC UPS and it comes with 10 outlets. but the battery only kicks off when its not connected to the outlet on the wall. i have it plugged into the wall at all times
issawm
Post
by issawm » 26 Sep 2024, 23:21
i also remembered my cousin came over my house and his pc setup was working correctly and mine wasnt thats what leads me to believe it isnt electrically related
