What ups have you got
Online double conversion UPS then power on PC
widow13
spkii
Re: Online double conversion UPS then power on PC
Do you have Computer, Display and Router connected to UPS? or Only Computer?
widow13
- Slender
skkiNN
Bro, i think gona give a try taking same USP as urs and see if it helps.. But i have a problem, my router is far away from my PC and monitor so i think i could plug only my PC and monitor, but not my router.... Did u try all your sistem without attaching the router? could u do a test maybe?
widow13
You'll be fine if it works, it doesn't matter. I plug my router just to be safe if the electricity goes down or something.skkiNN wrote: β10 Nov 2024, 18:12Bro, i think gona give a try taking same USP as urs and see if it helps.. But i have a problem, my router is far away from my PC and monitor so i think i could plug only my PC and monitor, but not my router.... Did u try all your sistem without attaching the router? could u do a test maybe?![]()
I used an extension to plug my router, you can use 1 if you want to.
skkiNN
Ye mate i was looking for an extension from amazon but didnt find anything, could u link me a product brodi?widow13 wrote: β11 Nov 2024, 05:44You'll be fine if it works, it doesn't matter. I plug my router just to be safe if the electricity goes down or something.skkiNN wrote: β10 Nov 2024, 18:12Bro, i think gona give a try taking same USP as urs and see if it helps.. But i have a problem, my router is far away from my PC and monitor so i think i could plug only my PC and monitor, but not my router.... Did u try all your sistem without attaching the router? could u do a test maybe?![]()
spkii
still good man? or came back the lag and stuff?widow13 wrote: β03 Nov 2024, 08:23[quote=Ogmax post_id=109542 time=<a href="tel:1730473188">1730473188</a> user_id=15781]
[quote=widow13 post_id=109520 time=<a href="tel:1730315131">1730315131</a> user_id=16271]
[quote=skkiNN post_id=109518 time=<a href="tel:1730312893">1730312893</a> user_id=10594]
[quote=widow13 post_id=108330 time=<a href="tel:1726904221">1726904221</a> user_id=16271]
I do.
[/quote]
I'm fine yes.
[/quote]
[/quote]
I have the Powerwalker VFI 1000 TG UPS On-Line 1000VA 900W
[/quote]
Do you have Amazon link to buy it and try? Thanks
widow13
Literally any can work, I use one that looks like this. You gonna need an extra converter.skkiNN wrote: β11 Nov 2024, 05:58Ye mate i was looking for an extension from amazon but didnt find anything, could u link me a product brodi?widow13 wrote: β11 Nov 2024, 05:44You'll be fine if it works, it doesn't matter. I plug my router just to be safe if the electricity goes down or something.skkiNN wrote: β10 Nov 2024, 18:12Bro, i think gona give a try taking same USP as urs and see if it helps.. But i have a problem, my router is far away from my PC and monitor so i think i could plug only my PC and monitor, but not my router.... Did u try all your sistem without attaching the router? could u do a test maybe?![]()
