MarkC MouseAccFix is fixing the spray in CS2 ? FSR on 1440p ?
mago
Post by mago » 29 Dec 2024, 10:19
did u notice that too ? or im placeboing ?
i did play without any acc using the option in windows settings
but this one just made it way better.
when moving the spray really hard to fix, ig there still same acc there to cause this
duno
Edit:
FSR ULTRA Quality helps lowing the CPU heavy duty
https://www.youtube.com/watch?v=AQkHvqercFA
edit:
use fixed memory timing in bios - do after memory is working with the xmp or the tunning u found
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Re: MarkC MouseAccFix is fixing the spray in CS2 ?
Post by Slender » 29 Dec 2024, 12:02
delete both smooth
mago
Re: MarkC MouseAccFix is fixing the spray in CS2 ? FSR on 1440p ?
Post by mago » 20 Jan 2025, 15:12
Still FSR happened to eliminate stutters quite much i think
tried few resolutions
1600x900 - PCL - 7-8ms
FHD - PCL - Same
4K - PCL - 12-15ms
disabling FSR doesnt seem to reduce PCL
but stutters comes back even in 1600x900
hope it will work for u
