How to change bios hidden parameters (videoguide)
Re: How to change bios hidden parameters (videoguide)
Post by Slender » 16 Jun 2022, 05:32
after change settings in grub you need to write "reboot", if you poweroff pc change not apply
kokkatc
Post by kokkatc » 22 Jun 2022, 12:30
Nice. Thanks for this.
I've been wondering about BIOS modding for awhile... definitely going to give this a try.
sherifmagdy32
Post by sherifmagdy32 » 23 Jun 2022, 03:44
Have been looking for something like this for a while thanks a lot for sharing
Kentar
Post by Kentar » 22 Jan 2025, 19:27
What is grub? I didn't see it on the video.
JimCarry
Post by JimCarry » 24 Jan 2025, 09:17
Thanks for sharing but this looks to hard and complicated for me.scewin was so easy just change setting restart and boom you are good,f@ck me.
agendarsky
Post by agendarsky » 24 Jan 2025, 10:22
JimCarry wrote:
24 Jan 2025, 09:17
send me your motherboard's name into dm , if you have flashback function i can unlock it for you.
btw goodjob slender 8-)
Post by Slender » 24 Jan 2025, 18:37
Kentar wrote:
22 Jan 2025, 19:27
use scewin, that new and simplest
JimCarry
Post by JimCarry » 25 Jan 2025, 01:25
agendarsky wrote:
24 Jan 2025, 10:22
JimCarry wrote:
24 Jan 2025, 09:17
i think i send you private msg with my mb model?
SeekNDstroy
Post by SeekNDstroy » 25 Jan 2025, 06:48
Slender wrote:
24 Jan 2025, 18:37
Kentar wrote:
22 Jan 2025, 19:27
Do you know/ have any idea if i use grub, and then try to scewin, will it work?
For some reason, my system freezes if i use the export cmd (with enablelua fix). So i had to use the grub.
However, recently i found that, instead of writing "export", if i copy-paste the full command inside of the command file, it works. Nice! Problem solved. Then i changed a few one & try to import. But it always says fail. Even without modifying anything, just export & import also fails.
As grub takes more time & precision, im not willing to flash a fresh bios just to check the scewin at the moment. I may do that later when i will get extra time. I need to be sure that scewin must require a fresh unmodified bios to work or not.
