CS2 The problem with the 1% Low average , 0.1 average
leventina
Ryzen 7600x RTX 3070 32 GB RAM 5 6000 CL30 . The game feels like a piece of shit on fps monitor tests low 1% AVG 0.1% AVG
- 3.png (148.08 KiB) Viewed 13128 times
- 2.png (152.57 KiB) Viewed 13128 times
- 1.png (153.01 KiB) Viewed 13128 times
JimCarry
Re: CS2 The problem with the 1% Low average , 0.1 average
volvo dont care about optimizing the game,people with old pc are ggs,dont worry new case in cs2 next week and -50fps.
joseph_from_pilsen
This limitation trick helped a lot to my friend with 5600X Ryzen. The limit just set to a value of minimum averages you can manage to keep. 7600X should be capable of 237fps minimum averages at 240hz monitor in 5v5 mode with good timings of RAMs.
https://www.reddit.com/r/cs2/comments/1 ... d_01_lows/
Of course, it wont help you if you have any jitter (network sided or server sided), this causes frametime spikes by itself and nothing helps. Always turn on telemetry.
JimCarry
this is my last benchmark result:joseph_from_pilsen wrote: ↑09 Mar 2025, 12:14This limitation trick helped a lot to my friend with 5600X Ryzen. The limit just set to a value of minimum averages you can manage to keep. 7600X should be capable of 237fps minimum averages at 240hz monitor in 5v5 mode with good timings of RAMs.
[VProf] FPS: Avg=551.5, P1=230.4
what should be my fps in game i have 240hz monitor ?
ryzen 5 7600x rx580 32gb ram 6000
joseph_from_pilsen
lock at 237fps following the reddit post i posted. If it still drops, get lower a bit (230 or 223fps)
JimCarry
ok thanks i will try it.joseph_from_pilsen wrote: ↑09 Mar 2025, 12:27lock at 237fps following the reddit post i posted. If it still drops, get lower a bit (230 or 223fps)
mocha__
if you want to fix 1% and 0.1% lows, dm me for my reddit post since i cant link anything here
my method, to my knowledge is the only way to drastically improve the frametimes
- RealNC
You reached 4 posts, so you should be able to post links now.
mocha__
hey thanks for letting me know that. well then heres a post i made about a week ago - https://www.reddit.com/r/cs2/comments/1 ... d_01_lows/
