CS2 The problem with the 1% Low average , 0.1 average
leventina
Post by leventina » 06 Mar 2025, 12:25
Ryzen 7600x RTX 3070 32 GB RAM 5 6000 CL30 . The game feels like a piece of shit on fps monitor tests low 1% AVG 0.1% AVG
JimCarry
Re: CS2 The problem with the 1% Low average , 0.1 average
Post by JimCarry » 07 Mar 2025, 10:38
volvo dont care about optimizing the game,people with old pc are ggs,dont worry new case in cs2 next week and -50fps.
joseph_from_pilsen
Post by joseph_from_pilsen » 09 Mar 2025, 12:14
This limitation trick helped a lot to my friend with 5600X Ryzen. The limit just set to a value of minimum averages you can manage to keep. 7600X should be capable of 237fps minimum averages at 240hz monitor in 5v5 mode with good timings of RAMs.
https://www.reddit.com/r/cs2/comments/1 ... d_01_lows/
Of course, it wont help you if you have any jitter (network sided or server sided), this causes frametime spikes by itself and nothing helps. Always turn on telemetry.
JimCarry
Post by JimCarry » 09 Mar 2025, 12:21
joseph_from_pilsen wrote: ↑
09 Mar 2025, 12:14
this is my last benchmark result:
[VProf] FPS: Avg=551.5, P1=230.4
what should be my fps in game i have 240hz monitor ?
ryzen 5 7600x rx580 32gb ram 6000
joseph_from_pilsen
Post by joseph_from_pilsen » 09 Mar 2025, 12:27
lock at 237fps following the reddit post i posted. If it still drops, get lower a bit (230 or 223fps)
JimCarry
Post by JimCarry » 09 Mar 2025, 13:41
09 Mar 2025, 12:27
ok thanks i will try it.
mocha__
Post by mocha__ » 11 Mar 2025, 14:04
if you want to fix 1% and 0.1% lows, dm me for my reddit post since i cant link anything here
my method, to my knowledge is the only way to drastically improve the frametimes
Post by RealNC » 12 Mar 2025, 02:49
mocha__ wrote: ↑
11 Mar 2025, 14:04
You reached 4 posts, so you should be able to post links now.
mocha__
Post by mocha__ » 12 Mar 2025, 13:07
RealNC wrote: ↑
12 Mar 2025, 02:49
mocha__ wrote: ↑
11 Mar 2025, 14:04
hey thanks for letting me know that. well then heres a post i made about a week ago - https://www.reddit.com/r/cs2/comments/1 ... d_01_lows/
