Mouse and keyboard Regedit settings
JimCarry
Re: Mouse and keyboard Regedit settings
Post by JimCarry » 06 Mar 2025, 11:58
Mr1991 wrote: ↑
06 Mar 2025, 11:31
Hyote wrote: ↑
06 Mar 2025, 10:42
Mr1991 wrote: ↑
06 Mar 2025, 10:21
Hyote wrote: ↑
06 Mar 2025, 05:45
Search for them manually or ask AI which may or may not know the setting correctly.
WorkNicely is described like this:
"Setting it to 1 makes the system more stable overall, but might make the keyboard unresponsive if a process hangs."
To me this means that extra resources are allocated to keeping the devices usable at all times at the cost of performance.
I believe you may have it the wrong way round? At least according to what I’m reading:
“The long and short of it is that setting it to 0 causes the KBDHID service to prioritize its own resource-allocation over that of other processes, ostensibly to ensure that the keyboard is always functional, likely to try to guarantee that Ctrl+Alt+Delete and/or Ctrl+Shift+Escape to access the lock-screen and to open the Task Manager, respectively, will always work”
So it seems setting it to 0 puts it in a priority state?
Yes but it seems like 1 is better when it doesn't prioritize the device. Even this explanation is a bit cloudy so I went with 1 based on feel.
Ah, are you sure it’s viable for the mouse hid too? Or did you just add it in?
krash
Post by krash » 10 Mar 2025, 11:02
Hyote wrote: ↑
05 Mar 2025, 19:56
I didn't want to make a separate post at first but it's been a while. These settings give me the most responsiveness but I'm not sure if WppRecorder_UseTimeStamp is present in versions other than 11.
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdclass\Parameters
ConnectMultiplePorts 0
MaximumPortsServiced 0
SendOutputToAllPorts 0
WppRecorder_UseTimeStamp 0
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdhid\Parameters
WorkNicely 1
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\mouclass\Parameters
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\mouhid\Parameters
UseOnlyMice 1
WorkNicely 1
Computer\HKEY_CURRENT_USER\Control Panel\Mouse
(all of these are String Values, delete everything else)
MouseAccel 0
MouseAccel_Max 0
MouseAccel_Scale 0
RawInput 1
it auto reverts WppRecorder_UseTimeStamp back to 1 ?
Hyote
Post by Hyote » 10 Mar 2025, 17:48
krash wrote: ↑
10 Mar 2025, 11:02
Hyote wrote: ↑
05 Mar 2025, 19:56
WorkNicely 1
UseOnlyMice 1
WorkNicely 1
MouseAccel 0
MouseAccel_Max 0
MouseAccel_Scale 0
RawInput 1
It happened to me once as well but it stayed on 0 after changing it again.
krash
Post by krash » 12 Mar 2025, 17:44
Hyote wrote: ↑
10 Mar 2025, 17:48
it still does revert every restart
JimCarry
Post by JimCarry » 13 Mar 2025, 14:00
krash wrote: ↑
12 Mar 2025, 17:44
Hyote wrote: ↑
10 Mar 2025, 17:48
so is it placebo or not ?
krash
Post by krash » 13 Mar 2025, 15:47
JimCarry wrote: ↑
13 Mar 2025, 14:00
it's slightly different i don't know if "WppRecorder_UseTimeStamp" has a bigger impact or would make it more noticable but i know the other one's made a slight difference
just screenshot what ur current values then apply if u don't like it, revert using the screenshots of ur previous settings
JimCarry
Post by JimCarry » 13 Mar 2025, 20:17
krash wrote: ↑
13 Mar 2025, 15:47
JimCarry wrote: ↑
13 Mar 2025, 14:00
thanks but no,like its ops job to post revert files,also not a single source for a single dword? all is on feeling 0 prove / source.but yeah you are 100% right before applying some randoms tweaks without source,maybe to backup/ screenshot.
krash
Post by krash » 15 Mar 2025, 20:14
JimCarry wrote: ↑
13 Mar 2025, 20:17
i understand why some people would want benchmarks over feel but it's kinda obvious when something feels different if ur good at something and something is off u would know it
also revert files aren't the greatest option i've had some revert files changing some settings to ones i didn't have before
