All you need (possible explanation for heavy movement feel)
FYNE
Re: All you need (possible explanation for heavy movement feel)
Post by FYNE » 20 Mar 2025, 06:16
AM5 plebs like me can try the hidden USB power saving settings. Disabling all of them is the 1st thing I do on a fresh install bc w/o the mouse really feels awful
JimCarry
Post by JimCarry » 20 Mar 2025, 12:19
[email protected] wrote: ↑
20 Mar 2025, 03:19
JimCarry wrote: ↑
13 Mar 2025, 13:49
13 Mar 2025, 07:45
Even for Intel and YOUR scewin there is no "Setup Question = Don't Reset VC-TC Mapping" option
ok so if not working for intel or amd then what is op using then ?
I think it was just a "joke"..... :/
i did not get it sorry
JimCarry
Post by JimCarry » 20 Mar 2025, 12:39
FYNE wrote: ↑
20 Mar 2025, 06:16
how to do that?
[email protected]
Post by [email protected] » 21 Mar 2025, 02:58
JimCarry wrote: ↑
20 Mar 2025, 12:19
@agendarsky is trolling
FYNE
Post by FYNE » 21 Mar 2025, 04:09
JimCarry wrote: ↑
20 Mar 2025, 12:39
FYNE wrote: ↑
20 Mar 2025, 06:16
how to do that?
With the tool PowerSettingsExplorer, disable 1 + 2 + 4 option in the USB section
JimCarry
Post by JimCarry » 21 Mar 2025, 13:45
FYNE wrote: ↑
21 Mar 2025, 04:09
JimCarry wrote: ↑
20 Mar 2025, 12:39
FYNE wrote: ↑
20 Mar 2025, 06:16
how to do that?
I have this tool but i still dont understand what you are talking about ?
FYNE
Post by FYNE » 21 Mar 2025, 18:09
Hub 0
USB selctive Off
USB 3 Link disable
JimCarry
Post by JimCarry » 21 Mar 2025, 18:11
FYNE wrote: ↑
21 Mar 2025, 18:09
Hub 0
USB selctive Off
USB 3 Link disable
do you have any source of these tweaks or just think it is better that way ?
deadmau94
Post by deadmau94 » 21 Mar 2025, 18:16
These options are not in AM5, right?
FYNE
Post by FYNE » 22 Mar 2025, 03:33
JimCarry wrote: ↑
21 Mar 2025, 18:11
FYNE wrote: ↑
21 Mar 2025, 18:09
Hub 0
USB selctive Off
USB 3 Link disable
just try it
you can revert any time
Locked
