All you need (possible explanation for heavy movement feel)
FYNE
Re: All you need (possible explanation for heavy movement feel)
AM5 plebs like me can try the hidden USB power saving settings. Disabling all of them is the 1st thing I do on a fresh install bc w/o the mouse really feels awful
JimCarry
i did not get it sorry[email protected] wrote: ↑20 Mar 2025, 03:19I think it was just a "joke"..... :/JimCarry wrote: ↑13 Mar 2025, 13:49ok so if not working for intel or amd then what is op using then ?[email protected] wrote: ↑13 Mar 2025, 07:45Even for Intel and YOUR scewin there is no "Setup Question = Don't Reset VC-TC Mapping" option
JimCarry
[email protected]
FYNE
With the tool PowerSettingsExplorer, disable 1 + 2 + 4 option in the USB section
JimCarry
I have this tool but i still dont understand what you are talking about ?
- what.GIF (6.52 KiB) Viewed 2777 times
FYNE
Hub 0
USB selctive Off
USB 3 Link disable
USB selctive Off
USB 3 Link disable
JimCarry
deadmau94
These options are not in AM5, right?
FYNE
