Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
Post
by Slender » 14 Apr 2025, 19:49
spkii wrote: β31 Mar 2025, 08:56
Plugging OFF House lights, only with Power Station Charged but no connected to house (With Computer, router and Display on it). Problem still appearing randomly... IDK This problem not related to electricty problems i guess then....
it could still be electrical related, but the reason is in the internal circuit of the pc, have you tried to do something with the power supply? You mentioned that you completely de-energized your house and only powered from your station.
I saw a video where a guy was trying to figure out why his guitar was making a low frequency hum and it was because of the transformer that was powering his house. The sound was there even when he completely cut off power to the house.
How was the internet connected? Have you tried full-offline mode with bots?
spkii
Post
by spkii » 15 Apr 2025, 03:26
Slender wrote: β14 Apr 2025, 19:49
What should i need to do with power supply? I tried offline with bots still happening btw.
UPDATED: Power Station charged and offgrid, connected to them: COMPUTER, DISPLAY AND ROUTER ONLY. ALL HOUSE IS WITHOUT ELECTRICTY WHEN TRYING THIS.
Actually I tried to move router far away from computer, will post results...
Post
by Slender » 15 Apr 2025, 03:40
spkii wrote: β15 Apr 2025, 03:26
try to completly disable wifi on router and use wire, or connect wire direct to pc
spkii
Post
by spkii » 15 Apr 2025, 09:41
Slender wrote: β15 Apr 2025, 03:40
Im trying it only with Ethernet from router to Computer disabling Wifi... will tell you updates, thanks guys btw.
spkii
Post
by spkii » 22 Apr 2025, 13:37
Well... tried in all ways... :
- No wifi, at first good after same...
- Only connected to Power Station: Computer and Display. (Router connected to house). Same problem.
- Tried all connected to Power Station, same.
- Tried with and without WiFi Peripherals, same problem.
IDK guys... Tried 2 diffferent computers, Displays, 2 different ISP... Cables of all types, (It happens too on PS5)... And this is 3rd house i tried (They are all near in my City btw 3kms or similar).
Post
by Slender » 22 Apr 2025, 23:30
spkii wrote: β22 Apr 2025, 13:37
can you try connect your power station / or pc psu to ground contact in socet?
spkii
Post
by spkii » 23 Apr 2025, 02:22
Slender wrote: β22 Apr 2025, 23:30
The thing is that i dont have a good ground on house (130V between Phase and ground, and neutral with ground too 130V, When it should be 230V if its a good ground...)
Post
by Slender » 23 Apr 2025, 02:25
spkii wrote: β23 Apr 2025, 02:22
use your neutral contact to ground
spkii
Post
by spkii » 23 Apr 2025, 03:02
Slender wrote: β23 Apr 2025, 02:25
its 130V too, and should be 230V-240V.
