Disabling PBO for Input Lag/Frametime consistency
Has anyone disabled tried PBO on their ryzen CPU to optimize frametimes/latency? I'm guessing that a CPU which is sitting at a particular frequency might not get as many 0.1% fluctuations etc since the CPU is not boosting up or throttling down.
Thanks
Thanks
Re: Disabling PBO for Input Lag/Frametime consistency
depends on what ryzen cpu,results may vary.Coldplayer wrote: ↑07 May 2025, 12:12Has anyone disabled tried PBO on their ryzen CPU to optimize frametimes/latency? I'm guessing that a CPU which is sitting at a particular frequency might not get as many 0.1% fluctuations etc since the CPU is not boosting up or throttling down.
Thanks
on older ryzens ive seen some people say its more stable but on newer ryzen gens no difference in framtimes/0.1%
do a test with capframex on a game 3 runs each game and compare
If you tell me how to do it i will do 1 benchmark now and now with it,and i restart pc after i apply and i will share results if you wish.Coldplayer wrote: ↑07 May 2025, 12:12Has anyone disabled tried PBO on their ryzen CPU to optimize frametimes/latency? I'm guessing that a CPU which is sitting at a particular frequency might not get as many 0.1% fluctuations etc since the CPU is not boosting up or throttling down.
Thanks
what ryzen r u onJimCarry wrote: ↑07 May 2025, 15:25If you tell me how to do it i will do 1 benchmark now and now with it,and i restart pc after i apply and i will share results if you wish.Coldplayer wrote: ↑07 May 2025, 12:12Has anyone disabled tried PBO on their ryzen CPU to optimize frametimes/latency? I'm guessing that a CPU which is sitting at a particular frequency might not get as many 0.1% fluctuations etc since the CPU is not boosting up or throttling down.
Thanks
7600xdrosku wrote: ↑07 May 2025, 17:17what ryzen r u onJimCarry wrote: ↑07 May 2025, 15:25If you tell me how to do it i will do 1 benchmark now and now with it,and i restart pc after i apply and i will share results if you wish.Coldplayer wrote: ↑07 May 2025, 12:12Has anyone disabled tried PBO on their ryzen CPU to optimize frametimes/latency? I'm guessing that a CPU which is sitting at a particular frequency might not get as many 0.1% fluctuations etc since the CPU is not boosting up or throttling down.
Thanks
I'm using a 5800x3d.drosku wrote: ↑07 May 2025, 13:26depends on what ryzen cpu,results may vary.Coldplayer wrote: ↑07 May 2025, 12:12Has anyone disabled tried PBO on their ryzen CPU to optimize frametimes/latency? I'm guessing that a CPU which is sitting at a particular frequency might not get as many 0.1% fluctuations etc since the CPU is not boosting up or throttling down.
Thanks
FYI I disabled PBO + Core performance boost and my cs2 feels alot more stable. I'm thinking of downloading MSI precision to lock my GPU clocks now as well to see if that helps too.
Locking GPU clocks will most definitely help with smoothness + u can underclock.Coldplayer wrote: ↑09 May 2025, 02:06FYI I disabled PBO + Core performance boost and my cs2 feels alot more stable. I'm thinking of downloading MSI precision to lock my GPU clocks now as well to see if that helps too.
Most likely there many guides on your particular GPU model, but still due to other hardware capabilities, make sure to try and find your own sweet spot.
did you do benchamrks before and after,or is it only feeling.Coldplayer wrote: ↑09 May 2025, 02:06FYI I disabled PBO + Core performance boost and my cs2 feels alot more stable. I'm thinking of downloading MSI precision to lock my GPU clocks now as well to see if that helps too.
i also lock my gpu this is my test results:Coldplayer wrote: ↑09 May 2025, 02:06FYI I disabled PBO + Core performance boost and my cs2 feels alot more stable. I'm thinking of downloading MSI precision to lock my GPU clocks now as well to see if that helps too.
[VProf] FPS: Avg=552.5, P1=230.7 -pbo enabled and Core performance boost enabled
restart pc run test again
[VProf] FPS: Avg=552.5, P1=232.8 -pbo disabled and Core performance boost disabled
