ok if there is something else i can do / show tell me.
Good news on solving the problem of input delay
JimCarry
Re: Good news on solving the problem of input delay
oenay
I think i know the problem of hit reg issue and more in cs2! Faceit server is broken, when i play dm i can kill 15 people in a row easy! My dm playstyle is so good, when anyone sees me playing dm and then in faceit, they think there are 2 other people playing this game. In console always pops this thing up with re sync .... every round. On dm server i saw it only one time! So there is a problem with this shit face it servers. Always writing hiperz the server provider and always the same, look winmrt test.bat files. And after that, they say make rate to 0 make this changes. No men this servers are bad!
cumitmuito
Bro, i wanna know if this AC filter fix the floaty mouse feeling for u? If it still fix your problem until this day, i will buy one right now.Inputlagger91 wrote: ↑14 May 2025, 01:40This is already a completed stage, believe me, what I have not already done in an attempt to solve this problemAsesino34 wrote: ↑14 May 2025, 01:09If you plug the monitor into a dedicated outlet — where the only thing receiving power is the monitor — there’s a difference. You should try connecting the monitor without that device you bought, and plug the PC separately, to see whether the difference comes from the device or from using a separate outletInputlagger91 wrote: ↑13 May 2025, 17:06Hello again from a guy from Russla. I won't write much, because it's already night, but I want to share the good news, recently I've been experimenting a lot with the settings of the Adrenaline application from amd and I think I did something and the game became better (cs2), it started to register better and the mouse is more, in short, it's playable, but the network filter started to make a lot of noise and I decided to change it. I bought a matihur (hifi) network filter today, but after hooking everything up to it, I caught a floating mouse again and so on, then I decided to leave only the monitor in it, and the computer in a separate outlet, reset the adrenaline settings, and set everything up again so that at least it was playable again. But later I decided to put the computer in the filter again and felt an improvement and this is not a placebo, even later I decided to take a risk again and reset all the settings and it didn't get worse, the main improvement in addition to a sharp mouse and more accurate aiming is controlled shooting with single bullets from such weapons as AK47 and M16, which has not happened since csgo. I will attach a photo of the filter. And I will try to keep you informed. I apologise for my English, I use a translator.
Inputlagger91
Hi, honestly, this filter didn't help. But now another topic helped, I'm sorry, I'm Russlan and it's night for me now, tomorrow I'll try to come here and write to you on a fresh head, what really helped me, I don't want to hurry, but for two days the mouse has become unrealistically fast, and it regs better and made a stable fps, I'm writing through a translator, so I apologise for the mistakes, be patient a little
Inputlagger91
Trust me, I've tried a lot of things for a very long time, and I can say with certainty that it's not a placebo. As chatgpt told me, I'm in a small number of people who are very sensitive to any slightest delaycumitmuito wrote: ↑28 Aug 2025, 07:27Bro, i wanna know if this AC filter fix the floaty mouse feeling for u? If it still fix your problem until this day, i will buy one right now.Inputlagger91 wrote: ↑14 May 2025, 01:40This is already a completed stage, believe me, what I have not already done in an attempt to solve this problemAsesino34 wrote: ↑14 May 2025, 01:09If you plug the monitor into a dedicated outlet — where the only thing receiving power is the monitor — there’s a difference. You should try connecting the monitor without that device you bought, and plug the PC separately, to see whether the difference comes from the device or from using a separate outletInputlagger91 wrote: ↑13 May 2025, 17:06Hello again from a guy from Russla. I won't write much, because it's already night, but I want to share the good news, recently I've been experimenting a lot with the settings of the Adrenaline application from amd and I think I did something and the game became better (cs2), it started to register better and the mouse is more, in short, it's playable, but the network filter started to make a lot of noise and I decided to change it. I bought a matihur (hifi) network filter today, but after hooking everything up to it, I caught a floating mouse again and so on, then I decided to leave only the monitor in it, and the computer in a separate outlet, reset the adrenaline settings, and set everything up again so that at least it was playable again. But later I decided to put the computer in the filter again and felt an improvement and this is not a placebo, even later I decided to take a risk again and reset all the settings and it didn't get worse, the main improvement in addition to a sharp mouse and more accurate aiming is controlled shooting with single bullets from such weapons as AK47 and M16, which has not happened since csgo. I will attach a photo of the filter. And I will try to keep you informed. I apologise for my English, I use a translator.
cumitmuito
BROOO, i just wanna say THANK YOU!Inputlagger91 wrote: ↑02 Sep 2025, 17:46Trust me, I've tried a lot of things for a very long time, and I can say with certainty that it's not a placebo. As chatgpt told me, I'm in a small number of people who are very sensitive to any slightest delaycumitmuito wrote: ↑28 Aug 2025, 07:27Bro, i wanna know if this AC filter fix the floaty mouse feeling for u? If it still fix your problem until this day, i will buy one right now.Inputlagger91 wrote: ↑14 May 2025, 01:40This is already a completed stage, believe me, what I have not already done in an attempt to solve this problemAsesino34 wrote: ↑14 May 2025, 01:09
Lucky that we are facing a same problem.
Lets me share my story, sorry for my bad English, its not my native language same as @Inputlagger91
In my case, im just moved to other house and comeback to CS2 after many years. The game is never being consistent for me, tried every tweak and test and it never be consistent (change 3 pcs, mouse, monitor 1 dedicated internet line for my PC gaming only), huge desync ingame and input lag, i cant even control my mouse and i have witnessed when i drop a gun in game, it just stuttered in the air before touch the ground (but still think its not a big problem related to my lag.
But one night i played very late at 3am~4am and 1 tap deag is ez af, even myself cant believe in my hand anymore.
Recently, when i took off my headphone, i heard my fan's (not PC's fan) speed is change for a short time (sound more quiet for few seconds and then comeback to normal), this is when i know my problem is related to electricity.
And then i found this post. I deciced to order a hifi AC filter like @Inputlagger91 even before admin approve my post here and it arrived today. I take time to reset bios setting, clean install windows, game, faceit AC (everything at default, plug my PC, monitor, router on it) and god damn, totally different feeling when i move my mouse on desktop screen and i dont have to say anything happen in first game with this AC filter. Worth any plenty for me.
akylen
Model of you hifi ac filter ?cumitmuito wrote: ↑03 Sep 2025, 15:56BROOO, i just wanna say THANK YOU!Inputlagger91 wrote: ↑02 Sep 2025, 17:46Trust me, I've tried a lot of things for a very long time, and I can say with certainty that it's not a placebo. As chatgpt told me, I'm in a small number of people who are very sensitive to any slightest delaycumitmuito wrote: ↑28 Aug 2025, 07:27Bro, i wanna know if this AC filter fix the floaty mouse feeling for u? If it still fix your problem until this day, i will buy one right now.Inputlagger91 wrote: ↑14 May 2025, 01:40
cumitmuito
The model i bought is Palivens P20, from China i guess. I also found model that @Inputlagger91 bought on AliExpress but i wanna order from a local store from my country to save time.akylen wrote: ↑03 Sep 2025, 21:31Model of you hifi ac filter ?cumitmuito wrote: ↑03 Sep 2025, 15:56BROOO, i just wanna say THANK YOU!Inputlagger91 wrote: ↑02 Sep 2025, 17:46Trust me, I've tried a lot of things for a very long time, and I can say with certainty that it's not a placebo. As chatgpt told me, I'm in a small number of people who are very sensitive to any slightest delaycumitmuito wrote: ↑28 Aug 2025, 07:27
- dervu
Why is this not in offtopic Niche Issues?
Also please hold off yourself with 1 day reviews...
Too many people experienced such issue to come back after much more time after connecting any kind of filter.
- themagic
This so true...
I had improvements just by plug in and switch to usb ethernet while was mid game and could immediately notice nice hitreg and mouse and easy tracking enemies and started so easy to kill but not for very long this fun haha...
There so many unexplainable things happened here with this "improvements" moments (cant even count them more and what tried...) and where i could clearly see and feel difference but it always dont last for very long much this good state...and if i tried to repeat/reproduce all the steps...it just dont worked more...improvement.exe stopped work.
like some fucking magic voodoo stuff shit that only works for once some moment and after dont more...even if you exactly repeat everything and step by step and try to reproduce this good state again...
Had so many times here the feel that i 100% Fixed my problem but everything always returned to bad and like it was before or even worse than that and how it was...
And such things and moments gave me always the most mindfuck here and where i still dont understand and cant exlain to myself till today this and leave me always with just more questions like "HOW THE FUCK AND WHY AND WHAT IS THAT SHIT?"...at the end.
Sounds maybe completely absurd but very real Story...
Guys who know and gone through this many times and such "improvements"...these will very well understand me and what im talking about and try to tell.
Edit:
Here just an example of such crazy unexplainable short improvement moment I had not so long ago:
- I only downloaded Auslogics Bootspeed
- After I clicked Optimized in Tweaker Manager everywhere and all Options and where it was possible and just apply/clicked some more random Options but manually.
- And apply Internet Optimizer Automatic which is something similar to TCP optimizer and stuff
Thats it. Saved everything and restarted PC.
And after the most fucked up mindfuck happened again to me and "improvement" which I could already notice on Desktop and how smooth everything was and mouse and just all...
Then i jumped fast in Valorant and join Unrated and dropped very most EZ 40+Kills in my life...Enemies had no chance at all against me and was like Bots that could not react to me and my Hitreg just connected perfect than everything what i had and saw before here...It was just crazy.
Now after this nice very Experience and "improvement"...guess what happened ? Yes right...everything degraded back to like bad and even on Desktop i dont feel more and stop to see this crazy smoothness which i saw just some Hour ago before...
Just some more short Story from me and so much about "improvement" where some People start think and believe that it is 100% FIX but later always realize that it was NOT really and just for some moment...
And yes I tried repeat/reproduce all steps but again NOT and NOTHING...
Fucked up hard or ? And how to explain these things to People that dont and never experienced such "improvements" or saw such huge "differences" ? and dont even gonna understand you if you start talk about that and such things ???
Edit: https://i.imgur.com/EgQsbgq.png
here the exact 40+kills moment and screenshot and day where this very short "SKILL" improvement happened to me and after the steps above and auslogics boostspeed and everything that i tell step by step...that how exact everything was and in exact order...nothing more and nothing less
just in case if you think and believe that i imagine that all in my head or talk crazy shit only again...
but this was the exact match where i could see and feel "huge difference" for once again and since long time and how things can change much and improve to your favor and all the advantage that comes with it...its huge and so much more easy to play that way...if only this good state last for some longer and dont degrade to shit just after lol...and that the real problem. where many struggle to solve or even to understand this all...
