dma remmaping disable (nvidia)
JimCarry
Re: dma remmaping disable (nvidia)
Post by JimCarry » 16 Jan 2025, 06:48
ahead wrote:
15 Jan 2025, 23:38
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nvlddmkm\Parameters
as i show in the screen i above i dont have this path, the only i have is "FTS".
SeekNDstroy
Post by SeekNDstroy » 16 Jan 2025, 10:07
JimCarry wrote:
16 Jan 2025, 06:48
ahead wrote:
15 Jan 2025, 23:38
Why there is nvlddmkm path for you? Did you have a Nvidia gpu? Afaik it is for Nvidia gpus. As you are using RX580, if you had a Nvidia gpu, you had to use DDU to clean the nvidia stuffs.
JimCarry
Post by JimCarry » 16 Jan 2025, 10:41
SeekNDstroy wrote:
16 Jan 2025, 10:07
JimCarry wrote:
16 Jan 2025, 06:48
ahead wrote:
15 Jan 2025, 23:38
i did use ddu and i never had nvida, i will delete the nvlddmkm key.
agendarsky
Post by agendarsky » 16 Jan 2025, 13:33
guys please do the usb 2.0 controller mode trick. No regedit tweaks will help until you fix root of the isue which is either bad usb driver or game engines cant handle such speeds without being incosistent.
JimCarry
Post by JimCarry » 16 Jan 2025, 19:16
agendarsky wrote:
16 Jan 2025, 13:33
explain the tweak or give link ?
Jonnyc55
Post by Jonnyc55 » 21 Mar 2025, 10:50
"DMA remapping isn't supported for graphics device drivers."
https://learn.microsoft.com/en-us/windo ... ce-drivers
Valid values for DmaRemappingCompatible:
Value Meaning
0 Opt-out. Indicates that your driver is incompatible with DMA remapping.
1 Opt-in. Indicates that your driver is fully compatible with DMA remapping.
2 Opt-in, but only when one or more of the following conditions are met: A. The device is an external device (for example, Thunderbolt); B. DMA verification is enabled in Driver Verifier
3 Opt-in
Say not supported for gpu driver yet my default is 3
JimCarry
Post by JimCarry » 21 Mar 2025, 13:27
Jonnyc55 wrote:
21 Mar 2025, 10:50
Value Meaning
3 Opt-in
you have nvidia right,if some one give the amd key i can make benchmakrs, before and after, i think for is this the key but i am not sure?
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\amdwddmg\Parameters]
"DmaRemappingCompatible"=dword:00000003
or
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\amdwddmg\Parameters]
Jonnyc55
Post by Jonnyc55 » 05 Jun 2025, 11:38
JimCarry wrote:
21 Mar 2025, 13:27
Jonnyc55 wrote:
21 Mar 2025, 10:50
Value Meaning
3 Opt-in
or
Sorry yes Nvidia, 3060.
In the link I provided in other post, I wasn't clear, it says in a warning box:
Yet we see this key for the GPU. I can only think, windows OS merely sees a PCI device, and adds the key anyway. However, there's no telling how Nvidia GPU will work with the registry key, maybe does something with it by itself. So mine was default 3, and I set it 0.
Well if it helps mine was in:
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nvlddmkm\Parameters, but yes. amdwddmg, no idea if that is the target for you.
JimCarry
Post by JimCarry » 05 Jun 2025, 16:37
Jonnyc55 wrote:
05 Jun 2025, 11:38
JimCarry wrote:
21 Mar 2025, 13:27
Jonnyc55 wrote:
21 Mar 2025, 10:50
Value Meaning
3 Opt-in
or
ok so if someone knows,maybe give source and maybe then benchamarks?
Jonnyc55
Post by Jonnyc55 » 06 Jun 2025, 12:35
I got temp banned in COD yesterday supposed cheating, these reg keys might trigger anti-cheat I wonder... DMA hack cards exist for games like CoD.
