No FPS gaming possible
Re: No FPS gaming possible
Post by Slender » 05 Aug 2025, 09:22
LaggyTyp wrote:
04 Aug 2025, 12:56
Time to Kill and Time to Death.
NetworkThrottlingIndex = 70 (Decimal) = Good
NetworkThrottlingIndex = 10 (Decimal) = Horror
NetworkThrottlingIndex = ffffffff (Hex) = Horror
WHY?
do you try disable mmcss service ?
LaggyTyp
Post by LaggyTyp » 06 Aug 2025, 12:23
I'm noticing something strange.
After I had everything set up and it was running really well, I started the "TimerTool" and saw that it automatically set itself to 1ms. It's been running like this for 2-3 days now (even after a restart).
I just wanted to play a round, and it's running poorly again. According to "TimerTool," I'm back at 15.625ms, even though I haven't changed anything.
Does anyone have an explanation?
I never set anything. It automatically set itself to 1ms.
Post by Slender » 07 Aug 2025, 08:01
LaggyTyp wrote:
06 Aug 2025, 12:23
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel]
"GlobalTimerResolutionRequests"=dword:00000001
why u ignore me?
LaggyTyp
Post by LaggyTyp » 13 Aug 2025, 10:18
The game is fully desynced, but I don't die that quickly.
bcdedit /set disabledynamictick no
The game is synced, but I die extremely quickly.
Whoever solves this puzzle gets an Oscar from me.
dermodemon
Post by dermodemon » 13 Aug 2025, 11:33
LaggyTyp wrote:
13 Aug 2025, 10:18
delete all your tick and platformclock values from bcdedit /enum
disable every offload possible in your nic settings
disable flow control in your nic settings
disable interrupt moderation in your nic settings
set your Buffering to smooth over packet loss in cs2 to NONE
type cl_interp_ratio 2 in cs2 console and play.
post the results later please
p.s. i found something weird. After i disabled above 4g decoding and rebar in bios, i have much smoother and enjoyable frames
LaggyTyp
Post by LaggyTyp » 13 Aug 2025, 12:36
Thanks!
I'm playing Battlefield 2042 + 6 (starting tomorrow).
Right now, I'm experiencing massive desync.
I'm hitting enemies, but they just don't fall over. It takes 2-3 seconds to take someone down.
I don't understand it. :cry:
LaggyTyp
Post by LaggyTyp » 13 Aug 2025, 13:21
bcdedit /deletevalue disabledynamictick
bcdedit /deletevalue tscsyncpolicy
bcdedit /deletevalue useplatformclock
bcdedit /deletevalue useplatformtick
I can't play at all anymore. It's impossible.
kriegsnake
Post by kriegsnake » 13 Aug 2025, 13:54
LaggyTyp wrote:
13 Aug 2025, 13:21
Play with whatever settings that you have better hitreg, but at the end of the month you will delete all of these settings , because there is no magic enable button.
LaggyTyp
Post by LaggyTyp » 13 Aug 2025, 14:01
I can't rule out the possibility that it's a local issue. Something caused by my motherboard (Z690), for example.
Does anyone know this option? What does it do? Turn it on? Turn it off?
BCLK TSC HW FIXUP
LaggyTyp
Post by LaggyTyp » 13 Aug 2025, 14:45
I suspect that in my case it is the timers (TSC / RTC) that are causing Desnyc.
Even though my BLCK is 100, the CPU clocks 0.0012Mhz higher than desired.
