[Radeon+MouseHz Interference] atieclxx calls GetRawInputData causing mouse jitter - patched w/ python!
ms.potatoe
Re: [Radeon+MouseHz Interference] atieclxx calls GetRawInputData causing mouse jitter - patched w/ python!
The problem is still not solved. It happens and is obvious at any polling rate ( 1000Hz, 2000Hz,... ).
- F1zus
Is this problem still not fixed in new versions of AMD drivers?
fjoecs
Did everything according to your instructions as lately I've been struggling with the interference and it definitely helped, thank you boss.
- kyube
AMD is notorious for their subpar HW cursor implementation (which is a known issue, as per 1, 2 and 3) and the issue explained in the OP.
I'm very certain that both are not solved as of October 2025 across RDNA GPUs.
DudeBeFishing
I just tried this patch with Adrenalin 24.6.1 and an RTX 6600. I'm getting about +-0.01 better mouse test results with a Logitech G400 set to 1000Hz polling. Not a huge difference, but it's measurable.
Most games ran fine before on this driver, so I can't really tell a difference. I haven't tested PUBG, but I really don't feel like it since it's 90% out of region players.
DudeBeFishing
I ran a few tests using the current driver release, 26.9.1 (Aug 25, 2025) . There's still an issue. By itself it's barely measurable, about 5Hz variance, but ideally there shouldn't be any difference. I don't use any Adrenalin software features, there's no need for this process to be polling anything.
CPU: AMD Ryzen 5700X3D
Motherboard: Asrock X570S PG Riptide
GPU: RX 6600
OS: Windows 10 Enterprise LTSC 2019, Version 1809
Mouse: Logitech MX518 Legendary.
USB Polling Rate: 1000Hz.
The mouse is connected to the "keyboard" port on the motherboard's rear IO.
https://pg.asrock.com/mb/photo/X570S%20 ... de(L8).png
atieclxx.exe running in background:
Interval vs. Time
1. STDEV: 0.01999095
2. STDEV: 0.01868336
3. STDEV: 0.01877345
Frequency vs. Time
1. STDEV: 20.01135757
2. STDEV: 18.69800281
3. STDEV: 18.79130248
atieclxx.exe disabled:
Interval vs. Time
1. STDEV: 0.01322392
2. STDEV: 0.01456746
3. STDEV: 0.01374009
Frequency vs. Time
1. STDEV: 13.38260732
2. STDEV: 14.65119219
3. STDEV: 13.77898963
GPU: RX 6600
Interval vs. Time
Frequency vs. Time
Interval vs. Time
Frequency vs. Time
- F1zus
Has AMD fixed this bug in the latest driver version, 26.9.2, or not yet?
