How I fixed my desync (fake scaling)
fjoecs
Post by fjoecs » 25 Oct 2025, 20:55
My desync started in 2021 when I upgraded my monitor to an Acer XF250Q (240 Hz) and bought a new PC. I’ve been playing CS:GO since 2014, always at 1280×960 stretched. Strangely, the game felt worse on 240 Hz than on my old 75 Hz monitor. Back then I was already posting on forums with titles like “240 Hz feels like 60 Hz”, suspecting that something was wrong with my monitor or configuration. Over the years I kept tweaking my system and upgrading PC components, but I always kept the same monitor. It’s also worth mentioning that I’ve always used AMD GPUs. The game consistently felt different, but never perfect... until I finally found a solution that worked for me.
This topic is not for everyone, as I’m using an AMD GPU. Monitor settings and specs also differ from one model to another. However, I hope this post helps other users, even with different GPUs/monitors by showing where the issue might be.
Recently, I discovered that for years I had fake scaling due to incorrect AMD and monitor settings. How did I realize this? When I launched CS2, sometimes it opened with black bars and only stretched after I clicked the mouse inside the game, and sometimes it opened stretched right away (seemingly at random). The game’s smoothness was always inconsistent, and the spray pattern in CS felt so “bursty” that it was difficult to control. There are plenty videos on Youtube about custom resolution, and in my experience most are incorrect.
How to find and fix the issue
First, here’s my monitor’s standard timing table. To find yours, go to your vendor’s website and check the specs/user manual/documentation. In my case, there's no 1280x960 resolution, which means that my monitor doesn’t provide proper hardware scaling for 1280x960 @240hz:
I tried both GPU and display scaling, and the game always felt off with both and now I understand why.
There are two methods to solve the issue:
1. GPU scaling
2. Display scaling (Custom resolution)
You might say that’s obvious, but the crucial part is getting the settings right on both the GPU and the monitor.
For proper GPU scaling on AMD
AMD settings:
Enable GPU Scaling
Scaling Mode: Full panel
Monitor settings:
Wide Mode: 1:1 or Aspect (this may be named differently on your monitor)
After this, you’ll have proper GPU scaling.
For proper display (monitor) scaling on AMD
AMD settings:
Disable GPU Scaling
Scaling Mode: Preserve aspect ratio
Monitor settings:
Wide Mode: Full (name may vary)
If your monitor doesn’t support 240 Hz at your in-game resolution and you want to use Display scaling, you’ll need to create it using Custom Resolution Utility (CRU). Example for 1280×960:
1. At the top of CRU, select the monitor you play on (active)*.
2. Add the standard resolution 1280×960 (60 Hz) if it’s missing.
3. Open your Extension block; in my setup it’s called CTA-861.
Under CTA-861 → Detailed resolutions, add a custom resolution. There are two approaches to try:
Approach A: Click Add, choose CVT-RB (reduced blanking), enter your custom resolution (e.g., 1280×960), and your monitor’s refresh rate (e.g., 240 Hz). If your native 1080p “240 Hz” actually shows 239.76 Hz, enter that exact value.
Approach B: Under Detailed resolutions, open your native 1080p 240 Hz entry and Copy it. Then click Add, Paste, change the resolution to 1280×960, and press OK.
In the CRU folder, run restart64.exe.
For years, my issue was that I always had incorrect AMD and Monitor settings that lead to incorrect both GPU and Display scaling. I had Wide mode Full when trying to force GPU scaling which forced both GPU and Monitor to stretch the game. Also vice-versa, and never the proper configuration.
Congratulations, you now have correct GPU/display scaling that won’t cause issues. With display scaling, you can still experiment with timings, but be careful and do your own research/testing. After a few games on FACEIT I found out that in my case GPU scaling feels better, probably because I have cheap monitor, but you can try both. Good luck!
dermodemon
Re: How I fixed my desync (fake scaling)
Post by dermodemon » 26 Oct 2025, 06:49
Well.
I have native 2560x1440 but always playing at 1920x1440 (4:3)
This fixed my random black bars when opening the game. Don't know about desync, but man thank you for that. It was so annoying to alt+tab every time random black bars appear.
Thanks
fjoecs
Post by fjoecs » 26 Oct 2025, 07:55
dermodemon wrote:
26 Oct 2025, 06:49
Well.
Thanks
Glad it helped you a bit. Also, I’ve seen you on Cybershoke DM so many times, you have a very memorable nickname :D
Hyote
Post by Hyote » 26 Oct 2025, 08:10
You should research this topic a bit more because these are still subpar settings you have. As always I'm going to refer to my GitHub guide.
dermodemon
Post by dermodemon » 26 Oct 2025, 08:29
fjoecs wrote:
26 Oct 2025, 07:55
dermodemon wrote:
26 Oct 2025, 06:49
Well.
Thanks
haha yes, i am playing there often :D
BARGHEST
Post by BARGHEST » 26 Oct 2025, 11:22
I've tested a lot in the CRU program and also decided to try what you suggested. The screenshots show that we have a similar situation with monitors, but I have a 1070ti video card, I set it up as you described above, but only the standard one works when locked, RB breaks the screen image. I set it up as standard, tried playing, well, yes, smoothness appeared, but CS stopped launching, sometimes in full, sometimes with black bars, and so on. It added a little smoothness but didn't fix the aiming from head to head, the accuracy remained the same. As a note to the author, try testing the game at 4-5 in the morning, maybe you will feel like you've become better at playing, and this is true, but still, thanks to the author, I had a small but hope.
amorou
Post by amorou » 26 Oct 2025, 15:58
fjoecs wrote:
25 Oct 2025, 20:55
1. GPU scaling
AMD settings:
Enable GPU Scaling
Monitor settings:
AMD settings:
Disable GPU Scaling
Monitor settings:
Congratulations, you now have correct GPU/display scaling that won’t cause issues. With display scaling, you can still experiment with timings, but be careful and do your own research/testing. In my case Display scaling using custom resolution feels better, probably because I have old 5700XT GPU, but you can try both. Good luck!
So that means all these years if you tried any other resolution your problem should ve been resolved.
Haven't you tried ?
fjoecs
Post by fjoecs » 26 Oct 2025, 16:39
amorou wrote:
26 Oct 2025, 15:58
Haven't you tried ?
I didn't try other resolutions as I always play on 1280x960. I don't change my in-game settings, only testing windows tweaks. What is more, it wouldn't fix this issue as I had amd and monitor settings that interfere with each other.
Also here you can see my last 5 games on Faceit where I was still testing my AMD/Monitor settings, I think u'll notice the difference:
amorou
Post by amorou » 26 Oct 2025, 17:06
fjoecs wrote:
26 Oct 2025, 16:39
amorou wrote:
26 Oct 2025, 15:58
Haven't you tried ?
Your monitors edid has native resolution at 240hz , so if you play at that resolution , how its different from you adding 1280x960
fjoecs
Post by fjoecs » 26 Oct 2025, 17:26
amorou wrote:
26 Oct 2025, 17:06
fjoecs wrote:
26 Oct 2025, 16:39
amorou wrote:
26 Oct 2025, 15:58
Haven't you tried ?
I don't like playing CS2 on 1080p resolution, that's why I'm playing on 1280x960 stretched. If i try to open CS2 with 1280x960 resolution without custom resolution I'll have black screen, that is why there are only two options for me, gpu scaling or display scaling using custom resolution. Both methods have to be properly configured.
