Ryzen vs Intel Input Lag/Latency
bbbe
Re: Ryzen vs Intel Input Lag/Latency
Post by bbbe » 27 Oct 2025, 01:43
donger wrote:
26 Oct 2025, 15:40
i have zero inputlag on 5800x3d and half of the streamers use 9800x3d and they have zero problems, don't buy shitty intel in 2025.
1) streaming what
2) what's your sample size
3) what is your and the streamers' mobos
If you can't answer these questions then it's hard to treat your statement as anything but anecdotal.
Plenty of people today probably play esports titles on something like an IPS panel and leave settings on default which usually leaves them with around +5ms input lag. And then I can assure you that 80% of them won't consider that being a massive gap because they never had experience of 1-2ms vs 5ms. Literally even my decade old TN panel on the lowest OD settings is nothing like highest OD. Ofc other panel tech exists but what I said just now is enough to make my point.
And also don't forget that we had decades of console gamers on tvs who have gotten used to +10ms of tv input lag if not higher, it doesn't mean that suddenly it should nullify what is being discussed here: "I'm okay with my xbox, why is this guy suddenly saying something against I like?" - Good for you. You enjoy that.
Just understand why I'm being rhetorical here, you've made two statements which none of them provide any useful information, such as: 'zero latency' or 'don't buy shitty intel in 2025'
Adeptstal
Post by Adeptstal » 28 Oct 2025, 08:52
Read only since 2024.Latest posts forced me to reg and share my exp about 9800x3d.
Not an Native speaker,wall of text ahead y v been warned.
I was using 13700k+ddr4+5070 mainly playing OW2.Zero issues, frametimes stable,no latency,lag or whatsoever.
After 480hz oled purchase,decided to buy 9800x3d.
Heard about Amd dip ,bad x3d 0.1 lows,microstatters and thought it just user error,bad setting etc .Cmon its almost 2026 whats just could go wrong.
But still spent 1 week chosing decent Mb+ram combo using AM5 MB sheet avoiding alc 4080 codec.
Boght 9800x3d+B850Aorus Elite wifi7(6 layers)+6000cl30 team group.
Setup Bios pb0 200 + x10 -15 Expo cl 30,disabled secured Bios,all securites,Tpm,spead spec etс.
Installed fresh Win 10 21h2 ltsc and damn,even in explorer i feel sluggishness.I dont feel 480 crispness anymore.Changed scaling mode to gpu + core affinity still not even close at intel.Played some games in Ow 2 Qp -get microstutters choppy framerate.CapFrame X shown huge frame time instability and horible 0.1 lows.
Tried:
All mobo bios ver.
Stock set.
Mainly:
Fixed overclock,stock,Pbo all freq,scallar etc.
Memory stock,All expo,Mainly,1:1 1:2 Fclk 2000-2067,Dif voltges etc.
C-states (on/off),Prefetcher set,Svm,iommu,df states etc etc
Even used scewin to tweak some hidden set.
win 10 21h2-22h2 ltsc-max,win 11 23h2-24 all orig iso.
All power profiles,chipset drivers and etc etc etc.
Abs same horib 0.1 lows and framespikes.
Thought mb its chipset or mb,but no,tons of post on reddit,youtube, about microstuters and 0.1 lows dif mobo,cpu,etc.
So i decided switch back to intel and sell Amd on second hand site with mark " i wont impressed by X3d ".And y know that?3 man Pm me and asked whats wrong with x3d,and they have abs same issue like " My 13600kf was smother than 7950x3d,9800x3d microstutering,7800x3d latency worse than my 14700kf.
I suggest all this problems caused by x3d archeticrure and most people not sensitive to it.
bbbe
Post by bbbe » 29 Oct 2025, 02:30
Adeptstal wrote:
28 Oct 2025, 08:52
It may be the case that whatever happens on the core is fast, like cache n such, but as soon as you have to leave to infinity fabric, maybe the combination of poor engineering choices on multiple system levels lead to a disastrous experience.
Realistically even if there is a massive speed/latency discrepancy in the architecture that alone shouldn't be enough to make hardware stuttery. Either electrical architecture is inherently unstable or the low level instruction design is a buggy mess which doesn't behave gracefully with os schedulers.
Who knows, maybe in reality for a stable x3d experience you need even higher roundtrip latency for fabric + core to have a tigher sync across these sections of the chip but maybe you have amd teams that pump out different results or those said teams work on one piece of the architecture at a time leaving the rest as is without a care in the world. Eitherway it's quite a degen way of designing anything. And this is quite ironic. Every time I give amd a chance they f*** something up. Takes me back to r9 290x with crossfire days. What a disgusting hack that card was.
Lucasged
Post by Lucasged » 29 Oct 2025, 07:59
Adeptstal wrote:
28 Oct 2025, 08:52
Tried:
All mobo bios ver.
Stock set.
Mainly:
I have the exact same problem.
I used to have an Intel i7-13700K with an RTX 3070. The FPS wasn’t as good as with my AMD Ryzen 7 9800X3D, but damn, it felt so smooth back then.
Ever since I switched to the AMD Ryzen 7 9800X3D, I’ve had issues getting good gameplay — I even bought a 400Hz BenQ XL2566X+ monitor (upgraded from 240Hz) hoping it would help, but nope.
I feel like I’ve tried everything in BIOS, Windows, etc.
Now I’ve put my PC up for sale so I can go back to Intel.
Vocaleyes
Post by Vocaleyes » 01 Nov 2025, 22:54
Lucasged wrote:
29 Oct 2025, 07:59
Adeptstal wrote:
28 Oct 2025, 08:52
Tried:
All mobo bios ver.
Stock set.
Mainly:
What mobo?
bbbe
Post by bbbe » 04 Nov 2025, 10:27
Coming back with updates, just tried a setup with m.2 riser to pci + via 805. omg. I can definitely feel the difference even between the usb2 cpu port. About 2ms+ less I think. At the same time it just feels more consistent. Idk why. I'm gonna get a photo sensor to really measure it and make sure it's not a placebo but so far I do think there is a certain difference. In the compositor I can tell that everything is much tighter and like timings wise just on point. Same goes for the games.
idk how I would measure consistency though... As I think there are even more gains in that than just latency. It just feels like it's back closer to what I had on my intel systems.
It might really be something to do with a bunch of amd mobos and usb implementations I have no clue. But I'm definitely feeling that i'm getting much more consistent clocking in the chain or something and overall lower latency.
gster
Post by gster » 09 Nov 2025, 14:10
Created an account just to share my experience.
Just switched from the 12900k to the 9800x3D with my 4090 on an lg OLED 4k120hz.
Using a beast X at 1000hz & the rog falchion rx at 1000hz too.
I had this exact same peripherals on the Intel set up, and the mouse felt so perfect every movement felt like the mouse cursor and my hand were 1 to 1. Now with AMD it is so inconsistent. I will do the same exact movement multiple times and the mouse will basically end up in a different area slightly, and it drives you crazy if you can notice it. Forget about any precision in a shooting game like cs2.
Immediately noticed mouse inconsistency issues.
Tried all different USB ports still the same.
Try different ram clocks.
Updated drivers fully.
tested in linux environment. Exact same feeling so it’s on a hardware level not just drivers from my understanding.
Fresh install of operating system.
Disabled Wi-Fi Bluetooth through bios.
Basically everything that you can try I have done.
There is 100% a mouse inconsistency issue on AMD platform in general.
I have a pcie usb card coming tomorrow. I will update if I feel a difference.
*Update* tried a PCI-E USB card with the ASM3142 chip and using the driver from station driver (or whatever), same crap when plugged into the PCI port. (it's being routed thru the chipset still not directly to CPU)
I have a M.2 to PCIe Riser coming tomorrow, based on the MSI MAG x870e diagram it states that only the M.2 port above the graphics card is direct to CPU so that explains why it feels the same when its just PCIe. I will use the riser with this card and update.
Unfortunately I have to move my boot SSD from that main port to a secondary m.2 port. ( Looks to make no real world difference in speed anyways)
gster
Post by gster » 11 Nov 2025, 13:59
bbbe wrote:
04 Nov 2025, 10:27
Please check out my last post. Was using the PCIe riser with the usb card a clear difference?
bbbe
Post by bbbe » 18 Nov 2025, 01:12
gster wrote:
11 Nov 2025, 13:59
bbbe wrote:
04 Nov 2025, 10:27
Hey, no yeah. For me I do feel like it's much more consistent. I do have via 805 however and afaik there are differences between usb chips. And specifically ASM not being that much of a benefit. You can pickup via 805 for pennies from aliexpress.
Other things that might have indirectly helped is tuning power profiles precisely a bunch with PowerSettingsExplorer on top of Lasso bitsum base profile. And ofc all the things like making sure the cores are not entering sleep states n such. Minimum processor thresholds maxed out. The one obscure setting that I think is kinda significant is "Processor performance time check interval". I have it set to max of 5000. Basically it's a tick based profiling mechanism and there is a guy on yt (search "THIS WILL DRAMATICALLY REDUCE YOUR LATENCY!", can't post yt links here) who found that it uses plenty of kernel time esp when you switch to performance profile which have this frequency increased dramatically from balanced which is an issue.
Another thing I tried playing with is MSI tool and I feel like MSI mode on defo had a slightly more consistent feeling. I still set my pci dev to high priority though.
Also in BIOS I indeed turned off all the dynamic clock garbage, power states and such. Fixed clock 5.2ghz. Idc about maxing out setup I just need consistency. Also set 6000mhz xmp from my stick. At first I tried maxing out timings but the issue it seems that if you get vsoc voltage high then the system becomes unstable real quick. Like i'm not joking. It's better to run the stick at 1.35v and I just left vsoc on auto on my board which spits out 1.272 v which is f- high, but if I set it lower manually it gets unstable pretty quickly as well.
Anyways, yeah, basically from what I can tell amd platform is a load of garbage in terms of stability OOB in my opinion. And indeed all these little stupid tweaks do get it to a much better state. At the same time it doesn't fully eliminate everything. Like for example on boot & win logon I will still have my cursor freeze consistently once for like .5s. And to some degree I could say that there are times where there is funny jitter moments.
But also I think with a lot of tuning I did get the system down to a point where basically in valorant if I'm missing a pixel aim then it's likely me. But also I think there is some truth to the fact that on today's systems and maybe especially ryzen peripherals clocks above 1000hz basically is a performance downgrade. The issue being is that the packet timings on usb 2 fit max into 1000hz for polling. So when manufacturers advertise 1khz+ polling rate and say you plug it into usb 2 port it's basically just tricks and not true 1khz+ polling. And this is something I haven't verified myself yet but even when you plug the peripherals into usb 3 it doesn't necessarily mean they will run in usb 3 mode. In usb 3 packet timings can be as short as to fit into 8000hz max. But yeah, that's another thing too. And so far idk I noticed that my mice that I have running at 1khz overall yields more stable experience and on intel I think it might be less of a pronounced issue but also not immune.
So tldr, good luck, this nightmare of a platform will have you pulling your hair out. But yeah, I do think with all these tweaks you can get it better. And frankly even though in some games the % lows are a disaster, still the fact that I can have my pc basically run on fixed 5ghz+ clock with fixed fan speeds, have network throughput pump out 2.5 GBe much faster and have generally higher fps than 14th gen intel that is enough for me to stay on this jitter fest. And also I couldn't get my hands on the best 14th gen mobo fast in my area. And gosh, are the mid tier intel boards bad. Like if you can't get to 7200mhz on intel then idk what the point of it is.
Also some tweaks from here did help (specifically network & usb ones in devmgmt)
viewtopic.php?t=11799
kyube
Post by kyube » 19 Nov 2025, 15:10
bbbe wrote:
04 Nov 2025, 10:27
You're free to share a ETW sample of your VIA VL805-based PCIe AIC.
Considering that I own a AIC of every USB xHCI controller released in the past decade (planning on hopefully releasing my testing data by the end of the year), the value you've thrown is complete nonsense. :)
