CS2 reflex,gsync etc(New PC-newbie)
hurryupabit
Post by hurryupabit » 10 Nov 2025, 11:52
Hello everyone!!
Nice to join this awesome community
I have amd 7 7800x3d , gpu 4070 super , ram 6000 with EXPO enable , monitor benq xl2540 240 hertz
What should i use in cs2?
Some ppl say gsync,vsync,reflex
other noreflex
other no vsync,sync
Thanks in advance!! :D
ArkoN
Re: CS2 reflex,gsync etc(New PC-newbie)
Post by ArkoN » 16 Nov 2025, 18:32
you should enable reflex and gsync, vsync off. CS2kitchen on Youtube made some good tests regarding that.
SYSTEM: AMD 9950 X3D, ASUS LC RTX5090 OC, ASUS X670E-F, 2x16GB Lexar CL26 6000, Asus XGF27AQWDPG
Post by Slender » 17 Nov 2025, 19:07
gsync(nvcpl)+vsync(nvcpl)+ultra low latency(nvcpl)+disable p-state(regedit)
kyube
Post by kyube » 19 Nov 2025, 15:47
hurryupabit wrote: ↑
10 Nov 2025, 11:52
Hello everyone!!
other noreflex
other no vsync,sync
The answer to your question requires a few sub-questions:
• Do you prefer using Dyac? (flicker/impulse-based approach)
• Do you prefer not using Dyac? (sample & hold approach)
Considering that your base vertical frequency (refresh rate) is way too low to use Nvidia's automatic frame rate limiter, which gets applied when using GSYNC&VSYNC&Reflex in conjuction with each other, I suggest that you try for one of these 2 approaches:
Impulse-based approach
Dyac=Premium
AMA=High or Premium (2 concrete preset overdrive settings)
Nvidia's 'Max Frame Rate' limter set to 480FPS or higher OR fps_max 0
Nvidia Reflex (in-game toggle)=Enable
I suggest against enabling Nvidia's Ultra Low Latency Mode in the Nvidia Control Panel, as it's meant to be used in games which don't implement Reflex (which uses in-game data to keep the render queue depth < 1 & thus eliminate what's referred to as 'GPU limited' scenarios)
Pros:
+Severe eye-tracked motion blur reduction (to ~800Hz)
+FPS>=Hz scenario eliminates the timing mismatch backlight strobing motion visual degradation
+Low render latency due to high frame time target
Neutral:
-'Tearing' (mismatch between frametime & refresh rate) artifacts may be unappealing
Cons:
-Light flicker from global scan backlight strobing (DyAc) can be a eye-strain concern.
-Additional processing latency penalty may occur
A bit more to read into: viewtopic.php?t=3555
Sample & hold based approach
Dyac=Off
AMA=High or Premium
Nvidia's 'Max Frame Rate' limter set to 480FPS (or to a value you can consistently get with your rig) OR fps_max 0
Nvidia Reflex (in-game toggle)=Enabled
Pros:
+No processing latency overhead from backlight strobing
+No rapid light flicker from backlight strobing
Neutral:
Cons:
-4,17ms pixel visibility time ('persistence') is still too blurry for some, most noticable when spraying
Here's a similar write-up I've done to above, but for frame rate locked games: viewtopic.php?f=2&t=14912#p118346
General notes:
I'd suggest only considering the use of the GSYNC&VSYNC&Reflex combination only on +540Hz TN models, as they have sufficiently high refresh rate to encapsulate the general frame rate values you'll be on when using a X3D-based microprocessor in CS2.
For CS2, from my rudimentary 'evaluation' using RTSS' reflex.ovl overlay preset:
fps_max (internal frame rate limiter), RTSS Reflex & Nvidia's Max Frame Rate (referred to colloquially as “NvLimiterV3”) are the only 3 options which don't affect the metric called “Nvidia Reflex Sim-to-Render Latency” (in reflex.ovl) with an additional frame of added latency. To word it differently — there is no added 'frame of latency' overhead with these 3 above.
This above was done with NVidia Reflex (in-game toggle)=Enabled.
I don't know whether the same behavior applies when Reflex is toggled off, as NvLimiterV3 behaves differently when Reflex isn't enabled.
Other external limiters (RTSS front-edge & back-edge, RTSS async) increase the “Nvidia Reflex Sim-to-Render Latency” by 1 or 2 frames of added latency.
Special-K is not usable, as most users who play CS2 use FaceIT, which is a kernel-level access anti-cheat client.
EDIT (10-01-2026):
Reflex in CS2 is non-functional when in HW:FLIP
Swapping to HW:Legacy Flip (by toggling disable FSO in 'Properties') completely fixes the behavior of Reflex in CS2.
hurryupabit
Post by hurryupabit » 06 Dec 2025, 12:08
ArkoN wrote: ↑
16 Nov 2025, 18:32
wait how can i do this?
do you have any discord to set it up properly?
kyube wrote: ↑
19 Nov 2025, 15:47
[snip]
My monitor doesn't' have DYAC and its 240 Hertz monitor.
What should i use?
kyube
Post by kyube » 14 Dec 2025, 09:59
06 Dec 2025, 12:08
What should i use?
The XL2540, which you've quoted, supports a backlight strobing solution as per: https://www.rtings.com/monitor/reviews/ ... wie-xl2540
I'd run fps_max 0, Reflex enabled & fixed refresh rate.
The 240Hz target is too high (time-based) to use variable refresh rate.
A 600Hz TN makes more sense for a VRR+VSYNC+Reflex in the sample&hold approach for CS2.
There's an arguement to be had to use Nvidia's 'Max Frame Rate' setting to a value which is 2x your refresh rate to keep the tearline somewhat static. I'd only use it in conjunction with Reflex, however, as they have a interplay.
EDIT (10-01-2026):
hurryupabit
Post by hurryupabit » 27 Jan 2026, 11:18
kyube wrote: ↑
19 Nov 2025, 15:47
10 Nov 2025, 11:52
Hello everyone!!
other noreflex
other no vsync,sync
Dyac=Premium
Pros:
Neutral:
Cons:
Dyac=Off
AMA=High or Premium
Pros:
Neutral:
Cons:
General notes:
EDIT (10-01-2026):
My monitor has no DYAC, It has only Gsync from nvidia compatible no dyac its benq xl2540 240 hertz . So what do you ou recommend me to use?
naporitan
Post by naporitan » 27 Jan 2026, 11:48
kyube wrote: ↑
19 Nov 2025, 15:47
EDIT (10-01-2026):
I think this is a misconception... Can you provide reputable research?
kyube
Post by kyube » 27 Jan 2026, 12:15
naporitan wrote: ↑
27 Jan 2026, 11:48
Open up FrameView and test yourself. Look at the Render Queue Depth column.
27 Jan 2026, 11:18
My monitor has no DYAC, It has only Gsync from nvidia compatible no dyac its benq xl2540 240 hertz . So what do you you recommend me to use?
I've already replied to you above....
No frame rate limiter (fps_max 0) & fixed refresh rate.
Enable Reflex.
That's the best you can do, assuming tearing is irrelevant to you.
hurryupabit
Post by hurryupabit » 27 Jan 2026, 12:26
kyube wrote: ↑
27 Jan 2026, 12:15
naporitan wrote: ↑
27 Jan 2026, 11:48
27 Jan 2026, 11:18
Enable Reflex.
Can you help me with this : -> EDIT (10-01-2026):
How to do it?
