For some reason, 360hz showed up again as an option but the 165/180hz custom refresh rates are also available...not sure what's going on here now
Argus
brownvim
Now that you have said that, it is really nice isn’t it. I would be playing in fullscreen and tabbing out with no black screen and I was assuming fullscreen wasn’t working in game and that it was just incorrectly staying in borderless all the time haha.
- OpenEye
When I use 10bpc, part of the NVIDIA panel turns pinkish/white. That's not normal, right?
Also, is it worth using a 10-bpc when all I really do is play games?
brownvim
Kyube, from my own testing with the same TestUFO patterns:
At 60 Hz ULMB, dropping the pulse width below ~30 gives a very noticeable jump in clarity (exactly as TFTCentral showed). It shows clarity difference across the whole PW range.
At 120/240/360 Hz ULMB2, lowering the pulse width slider has almost no visible effect on clarity — it mostly just dims the screen.
It really feels like the higher refresh rate modes are still locked (or limited) around the same ~25% duty cycle that normal VRR Pulsar uses, while only the 60 Hz mode got the full adjustable treatment.
MSIfanboy
tft central
- Screenshot 2026-03-21 205719.png (574.07 KiB) Viewed 2851 times
brownvim
To confirm we would need this test done at 120hz, 240 and 360hz modes. To my eyes the clarity stays the same across the whole pulse width range, or its a very subtle clarity change.
- RealNC
RonsonPL
True, but for some (for example for me) it's still unusable.
edit: I think I missed something important. So no adjustable pulse width for Pulsar, but Nvidia added proper 60Hz ULMB mode to Pulsar monitors? That's awesome. I mean, Pulse tech would've been better, but that's good. I guess I need to catch up with more than just recent 2 pages of this thread, sorry
previously written:
I'm a fan of retro games. What they ask for Pulsar monitors is already too much, but such an overpriced LCD should have perfect 60Hz mode clarity, period.
Unless they start providing that, I'm postponing my purchase. Too many compromises. No OLED blacks, no OLED colors, no 3D and flawed 60Hz mode? No, thanks. I'd rather keep my two old XL2411s and save up for a VR HMD upgrade, which would give much better results in games. If only it had 60Hz at all, but I guess having an additional Quest 2 is some kind of a solution, if I block updates and pray it won't get bricked by faulty internal flash storage, cause outside of that Q2 + old firmware, there's no chance for 60Hz even in HMDs (head mounted displays). We're going backwards
For retro arcade games, there's something magical to how you perceive the game when you have razor sharp image in very fast motion. I refuse to give that up and I'd rather torture my eyes with 60Hz full screen strobe, than pick something significantly blurier.
previously written:
brownvim
The new firmware has 60hz support and adjustable pulse width.RonsonPL wrote: ↑22 Mar 2026, 05:10True, but for some (for example for me) it's still unusable.
previously written:
But I think the adjustable pulse width in the 120, 240 and 360 modes is broken.
Retro games at 60hz look great on it, I don’t think there’s a modern display that does it better as it’s so bright.
liquidshadowfox
Honestly if nvidia updated pulsar to duty cycle of 20% instead of 25% I think it would look significantly better without ruining their algorithms too much changing from the original 25% imo. It would be 5x the motion clarity instead of 4x! I still think the higher refreshes are borked on the latest firmware, the images look blurry at higher refreshes past 200 fps vs how it looks below 120 hz (and there's the sharp double imaging happening between 100 - 200 hz on top of that).
