liquidshadowfox
Post by liquidshadowfox » 21 Apr 2026, 13:11
I think the problem with flicker below 75 hz has to do with them tying the flicker to changes in fps. When it's around the flicker fusion threshold (around 72) most people might not notice the change in flicker but the moment you go below that value, variable flicker causes immense strain on your eyes vs a consistent 60 hz flicker where the scaler knows exactly when to pulse the backlight.
That's why I think the suggestion I made of allowing users to define per game/software profiles for monitor display mode (Pulsar/Gsync/ULMB2/Fixed mode) should be implemented alongside Display refresh rate mode (setting max display refresh rate to say 60 hz or 120 hz for ULMB2) without having to mess around with a physical monitor joystick and OSD or relying on some 3rd party scripts most users won't trust or understand. Cause realistically, the people (me included) who want 60 hz strobing to be included in pulsar want it so they can enjoy games that are locked to 60 fps (legacy content, elden ring or any souls series game, smash bros, etc) where it might be better to just facilitate an "nvidia only way" that automatically switches to ULMB 2 mode whenever such a program is open on the windows desktop. I also think IF they implement this, they should also allow ULMB 2 to TEMPORARILY stop flickering the moment someone tries to alt +tab out possibly because playing elden ring at 60 hz ULMB 2 and then having a white background web browser behind it when you alt + tab out is a flash bang to the face (and makes the flicker unbearable).
I don't disagree with nvidia not wanting to decrease pulsar minimum fps, I just think they should
1. Implement the profile switching idea because it leads to a much more satisfying customer experience
2. Improve Gsync pulsar at higher fps (200 fps - 360 fps doesn't look as good as lower refreshes, not sure if it's because light diffusion is too slow OR because the frame timing window is so small, that 10% (or whatever they have it set to) deviation causes it to fire compensation pulses left and right that ruins the picture quality)
3. Give us the option to use ULMB 2 proper with option of selecting rolling scan (for less eye strain and less crosstalk) or global scan (more motion clarity but more crosstalk) because Asus PG27AQN looks sharper to my eye than Gsync pulsar at 120, 240 and 360 hz ULMB (yes the PG27AQN has more crosstalk and red phophor but I expected we'd at least get more clarity at such high refresh rates).
4. Investigate what's going on with reflex + Gsync pulsar because historically I have only known Vsync + Gsync + Reflex on/Ultra low latency mode was the way to go but I get significantly better motion clarity using RTSS frontedge sync in most of the games I've tested and only a couple of games play nice with reflex + pulsar because their frames seem rock solid.
5. Allow Gsync pulsar to work at lower refresh display states so folks who own a 40 series or older GPU don't run into the DSC black screen flicker issue that's been reported on here. They invested into the nvidia ecosystem, they should also be able to have a good product experience given this product actually does more for them than anyone else (since I find that NOT using frame gen with pulsar looks better than using frame gen, the clarity of this screen makes frame gen artifacts really show because there's little to no motion blur to hide them).
kyube
Post by kyube » 21 Apr 2026, 13:22
liquidshadowfox wrote:
21 Apr 2026, 13:11
I haven't investigated other VRR+PWM solutions (Aim Stabilizer Sync, DYDS 2.0, ELMB-Sync & others), but I don't think this is only present on Pulsar.
Erratic frametime (the most common thing in existence of gaming) = degradation of eye-tracked motion clarity benefits being apparent.
Even more so visible, since Pulsar targets really high strobe 'on' period
A way I can see them “fix” it is by adjusting the strobe 'on' period vs brightness curve in favour of the former, since the panel is already doing monstrously high voltage boosting (DyAc levels, which isn't a thing on any other ULMB-based display I've seen)
I hope they go with that route, especially for ULMB2.
A 1700-2000cd/m² voltage boosting panel has to be used properly :D
21 Apr 2026, 13:11
It already works on QHD@240Hz@8bit without DSC through the DP1.4 port... so I don't see the issue there.
HDMI 2.1 FRL6 & QHD@360Hz@8bit (no DSC) very likely won't happen on this set of Pulsar products...
liquidshadowfox
Post by liquidshadowfox » 21 Apr 2026, 13:47
kyube wrote:
21 Apr 2026, 13:22
21 Apr 2026, 13:11
21 Apr 2026, 13:11
I've actually tried both stabilizer sync and elmb sync. I can tell you they worked more consistently than this gsync pulsar monitor BUT I'd argue that they had some downsides
1. Significantly more crosstalk
2. red phosphor (so low fps looked worse)
3. Actual VRR flicker if the changes happened too abruptly
so I think if the "freesync" alternatives avoided the issue, it was mostly because they weren't doing a good job in the first place imo. My last ELMB sync monitor that I thought was "ok" was the Asus XG27AQMR but it only worked well above 200 hz (below that crosstalk started to show up worse than what it already was) and it also had red phophor which made lower fps gaming on it messy compared to Gsync pulsar. Gsync pulsar HANDS down destroys the XG27AQMR so it's a straight upgrade from that at least.
kyube
Post by kyube » 21 Apr 2026, 13:55
21 Apr 2026, 13:47
Sadly, there's only a handful of good G2G RT panels which help avoid this problem...
The only IPS LCD panels I've seen are the ones found in the PG27AQN & XG27AQNGV (AUO M270DAN10.x)
21 Apr 2026, 13:47
Largest pitfall of the vast majority of panels nowadays, in regards to strobing..
21 Apr 2026, 13:47
I assume you mean visible (to the 'naked' eye) light flicker?
It's a shame that you haven't seen YAG-phosphor and/or QD-based solutions, other than these Pulsar models.
Though, to be frank, I cannot recall any other ones available on the market right now apart from the recent Titan Army models...
liquidshadowfox
Post by liquidshadowfox » 21 Apr 2026, 14:13
Yes flicker that's visible to at least my naked eye, it was like a momentary large white flash if the fps dipped too fast from a high frame rate to a lower one. I begged asus on their forum to update it but it wasn't an "upgradable firmware" model so it was planned obsolescence :(
John Blur
Post by John Blur » 22 Apr 2026, 05:18
Hello, I'm interested in this monitor and I have 2 questions that I could not find an answer to. I know the HDMI ports are 40gbps which should make 1440p @360hz usable without DSC, but are the HDMI ports still limited to 120hz for some reason? Is there no other choice than using the DP ports with DSC if I want the full 1440p 360hz? Finally, I know this monitor offers a 25" mode which is really important to me. It's my understand from looking at the specs on the Asus website that it's pixel perfect for 2368x1332 at 25", but I'm more interested in the 1080p resolution at this size to maximise framerates. Would the 25" 1080p mode be blurrier than a native 25" 1080p screen because of weird pixel scaling?
tsarri
Post by tsarri » 22 Apr 2026, 05:54
Latest nvidia drivers have significantly reduced the DSC black screen flicker issue for me on a 4070ti.
bahamutfan
Post by bahamutfan » 22 Apr 2026, 07:47
RealNC wrote:
21 Apr 2026, 09:49
bahamutfan wrote:
21 Apr 2026, 07:01
Is the 48Hz update that was announced still in the works?
I believe they said no, they didn't consider the flicker below 75Hz in pulsar mode acceptable.
I ask mostly for the ULMB2 mode so that various sub-60Hz retro content benefits from the clarity as well. Hopefully they'll reconsider...
t2na
Post by t2na » 22 Apr 2026, 15:52
John Blur wrote:
22 Apr 2026, 05:18
Yeh, the only way on the Pulsar monitors to reach 360hz 1440p is with DP 1.4 (with DSC). If you read back a few posts Kyube has asked Nvidia’s rep in here about it too.
I have the Asus model and the 25” cropped mode actually looks really nice at 2368x1332. 1080p looks blurred and almost like it’s out of focus - so if I use the 25” mode I just stick to pixel perfect!
CriticalHit_NL
Post by CriticalHit_NL » 22 Apr 2026, 17:49
I am coming off an at this point 10 year old Asus PG279Q Native G-sync 1440P AHVA-IPS 165Hz panel, which I've always set on Normal OD which seemed to be the most optimal, even though the pixel response tests were slightly less according to tftcentral when it came to 144Hz to 165Hz but I'll take that little extra smoothness in frames with Normal OD set and it has been a good time.
But recently since the 7th of March I've switched the PG279Q out for the new Asus Pulsar model and thus far my experiences have been amazing, I've been keeping an eye on this thread and places like overclockers uk forums as well to win in some information and experiences from the early-adopters because I couldn't get hold of one until two months later (and the other brands here still appear absent)
At first I had the old firmware and noticed some oddities with ghosting trails at lower framerates with the lower limit set to 75Hz and sometimes random bright flashes, probably from big fps fluctuations, I was panning around the camera in Planet Coaster 2 where I noticed this as the only easy reproducible game. But after the new firmware update it appears to have improved, though the aforementioned double-ghosting image trail is very much noticeable in games in the framerate ranges mentioned, I could definitely see it in smooth frog too.
I can still see the Pulsar flicker slightly at 100-120 fps when I look at the blue bright sky with some clouds in a game like Just Cause 2 but what I noticed is that when the lower limit is set at 75Hz the flicker seems more noticeable in these FPS-ranges than where it was set at 90Hz lower limit, not sure why, maybe some pulse width or compensation behavior changes when changing the limit but it was something I noticed, I am very sensitive to this though and not all may see this, the flicker is also really faint.
I was hoping to see the 48Hz lower limit but I can fully understand that it gets too much, I tried the 60Hz ULMB2 mode with the default 24 PWM and wow I am not someone who can handle that kind of black-frame flashing for a very long time, but the picture was definitely clear and for the people who want this perfect motion-blur-less 60Hz content that is perfect. I am okay with it just being G-sync native only below that threshold, the sample & hold behavior is acceptable for me personally there for lower fps motion as I had no issues playing in the 40-70s with G-sync on the PG279Q which then still felt acceptably smooth due to the 'blur' introduced, that was back on a 1080Ti with Ultra settings.
I currently have it setup with some cheap 3 meter passive DP 1.4 cables from amazon with HBR3 specification, HBR3 seems to be a must-have as I tried a 8K 60Hz "DP 1.4a" cable of 3 meters that didn't have HBR3 and it couldn't even drive my PG279Q DP 1.2 monitor beyond 85Hz, the Pulsar monitor is also working perfectly fine with it at 360Hz 10-bits with and without HDR.
The monitor always wakes up in 360Hz with Pulsar enabled for me in 10-bits mode, but I think that is due to the fact I'm running a RTX 5090 with the newer displayheads which should only use a single display pipeline to drive this with DSC enabled, it seems a little unfortunate that the older GPUs struggle a bit more with this negotiation, part of the reason I held of buying a new videocard since the 1080Ti as that was already DP 1.4 equipped.
This also allows me to use DSR/DLDSR on the monitor, even at 8K using a DSR Hex Calculator 'trick' to enforce higher resolutions on my monitor through registry edits the monitor sticks to 360Hz mode with Pulsar enabled and everything. Unfortunately probably out of luck on doing this with RTX-40 or older GPUs. This is just something I sometimes use on older games that lack things like DLSS/DLAA or any other proper form of anti-aliasing and just in general making the picture a bit crisper for distant content as well minimizing the shimmering of 3D models in the far distance in motion.
That being said I am absolutely loving how sharp the image stays during 200-300+ FPS situations, even with 6x MFG in games like Cyberpunk 2077 and Avatar Frontiers of Pandora going beyond 300 FPS it works incredibly well even for that, and hopefully soon with the new firmware 1.1.6 version on lower ranges too, this kind of image motion smoothness is something I hold dearer to me than something like HDR or higher contrasts. Maybe in the future we can see MiniLED displays with Pulsar combining the best of both worlds together as MicroLED/OLED can't support Pulsar due to the self-emitting nature.
HDR also works fine though, while not as spectacular as OLED could provide I am finding myself using it in the games where it is supported, it gives a bit more life-like feel to it in games that are using it properly.
My brightness of Pulsar is set to 350 as I found 500 too bright for general use also due to its whitier whites than the broken white the PG279Q provides, which is set to 75% brightness, while contrast and RGB is all set to 100 on the Pulsar, for G-sync only mode it is configured at 400 as I found that the switch between Pulsar on/off seemed pretty seemless in brightness like that as Pulsar gets brighter than regular G-sync mode. Out of the box it was far too dim on regular mode for my taste, somewhere in the low 200s.
With HDR enabled the display does get a bit hotter, likely due to it pushing more brightness than what I've set normally, but fortunately it has been working very well without any shutdown notices I've seen some users report. I only have to deal with 1 pixel that is stuck on deep-red but otherwise the monitor is mint.
There are however some things I like less about the panel, partially it could be a Mediatek limitation, otherwise it's mostly just general build quality things I like lesser versus the PG279Q
  • 1. Can't disable DP/HDMI deep sleep like PG279Q
    This means that the display will entirely disconnect from the system and move the open windows to another monitor, that is kind of annoying as when you turn it back on it reconnects it does change the primary monitor but the windows stay on the other monitor. So I had to make window profiles in DisplayFusion so I can just 1-button click everything I have open back into the positions I like.
    Another caveat for this could be connecting remotely to the system, as the monitor is not detected it can't be used as a remote display, e.g. for software like Parsec or Steam Remote game streaming over the internet, as my PG279Q and BenQ BL2411PT both have the option to disable Deep Sleep these remain active, it does mean the games I run remotely over steam will be adhering the V-sync limits of that PG279Q.
    It will sometimes also confuse games, because some of them will remember the secondary monitor as the primary monitor after being used remotely, so the next boot up the game ends up booting on the wrong monitor. Something I did notice with DOOM The Dark Ages for one, sometimes even with WoW though I don't play that remotely so the Primary monitor number must be shifting around due to this.
  • 2. The monitor is not instant-on like the PG279Q, this is probably due to the fact the PG279Q is always 'connected' with the aforementioned, it has a boot up time of atleast 8 seconds or so before display is resumed.
  • 3. The build quality overall just seems on a less high level than the PG279Q once was but this is not related to Pulsar itself in any way, just Asus dropping the ball in my opinion and is likely found back on similar Strix models as well.
    * The joystick is loose and rattles when touching it with your finger, PG279Q didn't do this, same for the buttons.
    * Buttons and joystick are harder to press
    * FPS-overlay is permanent black-background, PG279Q had yellow letters without a background, so it blocks more of the view.
    * FPS-overlay interferes with OSD-control, it is basically always listening to joystick input to move it around but you can't open the OSD without clicking the Joystick then until you turn the overlay off.
    * FPS-overlay position is constantly reset every time the monitor is turned off and back on
    * The backside where the cables has an upstanding edge at the bottom, larger cables interfere with this edge leading to bending
    * The Power-LED light can be seen from looking from above vertically down the bottom bezel, not possible on the PG279Q
    * Access to the VESA mount was more cumbersome and the looks of it after the mount look less clean than the square hole the PG279Q had.
Now I have two G-sync Displays I also noticed that the G-sync toggle counts for both displays at once and not individually, I am not sure about the reasoning behind this but it is generally not an issue.
ManuelG, if you are reading this;
It seems like recent driver versions have broken something for the older PG279Q G-sync panels, because whenever the monitor goes to stand-by mode and wakes up later, it won't resume with G-sync enabled (the indicator turns white) even though the Pulsar monitor remains nicely in G-sync/Pulsar activated mode.
The Nvidia Control Panel will tell you G-sync is active, while one monitor lost access, and it did this also prior the installation of the Pulsar monitor, it is interesting the Pulsar is not showing this behavior. So you need to turn off and back on G-sync to restore G-sync access on the PG279Q.
In certain games G-sync with MFG is not working correctly either, taking DOOM TDA as an example, whenever 2x mode is changed to 3x or 4x mode, the game becomes jittery in motion, especially noticeable when sprinting around the 'Ripatorium' I use for testing. That is with 1440P Path Tracing & DLAA enabled with everything maxed with high framerates. I don't believe that is a hardware capacity problem for the RTX 5090 as Cyberpunk 2077 or Avatar Frontiers of Pandora with similar GPU-load, DLAA and PT do not show this behavior, not even at 6x MFG in fixed mode with Preset B and Preset E.
Once G-sync is completely disabled, that issue disappears, and it does not occur with MFG for every type of game.
With the PG279Q 165Hz monitor I even noticed erratic GPU-utilization issues (it drops randomly) when G-sync was enabled with MFG because it would get stuck around ~327-333 ish FPS instead of pushing for 500 FPS in GTA V Enhanced which also led to visual issues with MFG, usually triggered by alt-tabbing but it does it at random ingame too, but it would not get this issue when G-sync was completely turned off. The game settings did not make any difference nor forcing off V-sync through the drivers.
I have seen someone report a similar issue with Black Ops 7 on the Nvidia Driver Feedback topic before and it appears to happen when MFG was pushing beyond 250+ FPS for these games while the Hz cap of the monitor is lower. It is almost like it is miscalculating something. When I set the monitor to 100Hz mode the ingame FPS would drop to ~228 instead of ~333 which seemed really odd to me meaning something is going wrong with how MFG is functioning at high framerates.
For the Pulsar using RTX Remix games like Portal RTX or Half-Life 2 RTX with 3x MFG and DLAA at 1440P they work completely fine and smooth, but once you turn on 4x MFG the microstuttering starts. I am a bit at a loss to understand why it is doing this but I can only report this and hope the best for it.
Note that my experiences are based on Windows 10 22H2 x64 Pro with ESU.
In any case, thanks for all the updates and information everyone has shared thus far, and thanks to brownvim getting in touch with Nvidia over that ghosting issue (I did as well but by other means) and thanks ManuelG for giving us a heads-up!
This monitor technology has a lot of potential, I know it is not perfect yet and we're still in the early stages despite a long time of R&D due to its complexity, but once perfected I would love to stick to this technology as much as I've wanted to stick to Native G-sync with the extra's Native G-sync provides all this time. I am just happy we're getting closer to eliminating that sample & hold blur as much as possible because it is a joy panning around the camera and things being actually trackable and readable in many games.
And while I thought the PG279Q already had decent smoothness and I did believe that higher Hz had more potential, this 360Hz monitor just blew me away with how much more difference it still gives, even just the input for moving the cursor on the desktop is incredible.
Main System:
i9 13900K @ 0.06v undervolt 0x10B microcode / 128GB (4x32GB) Corsair Dominator Platinum RGB DDR5-5400 CL40 XMP / Asus ROG Maximus Z790 Extreme (early 0219 bios, Sept 2022) / Asus ROG Astral RTX 5090 OC / 2x 990 Pro 4TB / 3x WDC Ultrastar HC590 DC 24TB / 3x HGST He10 Ultrastar 8TB / 1x HGST 7K4000 Deskstar 4TB / Corsair iCUE H170i Elite Capellix LCD 420mm AIO (6x Noctua NF-A14 IndustrialPPC 3000RPM) / Corsair AX1600i PSU (2025) / CoolerMaster HAF 700 EVO / Asus ROG Strix Pulsar XG27AQNGV 1440P 360Hz / Asus ROG Swift PG279Q 1440P 165Hz / BenQ BL2411PT 1200P 60Hz
Secondary System:
i7 3930K @ 4.8Ghz 1.4v / 32GB (8x4GB) Corsair Dominator DDR3-1866 CL9 XMP 1T / Asus Sabertooth X79 (2012 bios 3102) / EVGA GTX1080Ti FTW3 / 1x 840 Pro 256GB / 1x 860 Pro 2TB / 2x HGST 7K4000 Deskstar 4TB / Corsair iCUE H115i RGB Elite 280mm AIO (stock fans in pull) / Corsair AX1200i PSU (2014) / CoolerMaster HAF XM
Third System:
i7 950 @ 3.2Ghz turbo / 24GB (6x4GB) Corsair Dominator/Vengeance DDR3-1600 CL9 XMP / Asus P6T Deluxe V1 X58 / Asus ProArt RTX 4060 8GB / 1x 840 Pro 256GB / 1x WD Blue 1TB / Corsair HX750i PSU / CoolerMaster V6-GT CPU-cooler / CoolerMaster HAF 922
Fourth System:
Core 2 Quad Q9550 @ 2.91Ghz / 8GB (2x4GB) DDR3-1066 @ 1098 Royemai (SK-Hynix) / Gigabyte GA-G41M-Combo (Rev. 2.0) @ 343 FSB / EVGA GTX 560 SuperClocked 1GB / 1x860 EVO 500GB / 1x Samsung HD502HI 500GB / Artic Freezer 7 Pro Rev 2.0 / Corsair HX750i PSU / CoolerMaster Elite 331
