liquidshadowfox
Post by liquidshadowfox » 30 Apr 2026, 22:49
Love this monitor, been enjoying all my games at 90 fps locked with Gsync pulsar. I can't wait for the update to unlock 120 hz working without the double imaging :) still waiting on the asus update, I think Gsync pulsar works well into 190 hz, above that I think there's diminishing returns with how it's implemented. I really hope they give us an option to enable more flicker for more clarity.
brownvim
Post by brownvim » 01 May 2026, 05:20
Whats the best settings to use for Counter Strike 2, when it boots up the game it asks you to put it into Gsync + Vsync + Reflex, but this mode doesnt look smooth to me and the frame rate is moving around alot.
kyube
Post by kyube » 01 May 2026, 05:47
brownvim wrote: ↑
01 May 2026, 05:20
On good hardware, capable of +400FPS, I wouldn't even consider using Pulsar.
Only ULMB2 with a good frame rate limiter or NV Fast-Sync, depending on which refresh rate one chooses.
Reflex is broken in that game, it's better to rely on external Reflex toggles (SK or RTSS after presentation)
brownvim
Post by brownvim » 01 May 2026, 06:17
Is Special K safe to use, doesn’t risk VAC ban?
I get over 400 frames so need to cap it.
Using Pulsar or ULMB2 at 360hz makes no difference to clarity, so might aswell stay in Pulsar.
Edit: actually I see your point, ULMB2 would get around the compensation pulse, I would have to test both.
BLooDS_inc
Post by BLooDS_inc » 01 May 2026, 08:33
Lol, if u have 700-1000 fps mb u will have a good prio over pulsar, but if u have 400 and u can use pulsar with 345-349 u will use pulsar, cause ~349fps and 400fps don't have any human eye diff, but pulsar have big diff in motion clarity
bahamutfan
Post by bahamutfan » 01 May 2026, 09:46
I know the Nvidia rep said they’re not going to lower the floor on Pulsar, but I seriously hope they reconsider expanding the ULMB2 range to 48 - 70 Hz for additional compatibility with retro consoles and PCs.
kyube
Post by kyube » 01 May 2026, 10:41
brownvim wrote: ↑
01 May 2026, 06:17
Anecdotally speaking, a acquaintance of mine used it fine on normal matchmaking. It's gray area :P
Don't use it for FaceIT though, that'll definitely prevent it :D
brownvim wrote: ↑
01 May 2026, 06:17
Precisely that :D
The raw frametime difference is also too good to give up on, as some hardware can push +500FPS with relative ease in CS2
You could also run 240Hz ULMB2 and use NVidia Fast-Sync, if you can maintain 480FPS.
bahamutfan wrote: ↑
01 May 2026, 09:46
Save your eyes and play games which won't need that range or rely on LSFG / Nvidia Smooth Motion.
BLooDS_inc wrote: ↑
01 May 2026, 08:33
That range is insufficient for normal VRR use.
≤324FPS @ 360Hz is the range you want.
bahamutfan
Post by bahamutfan » 01 May 2026, 11:09
@Kyube
The thing is, you can’t really apply frame gen on retro consoles or a Mister piped through a scaler unless you use a video capture card, at which point you can use literally any monitor instead.
Would be great if there was a singular modern monitor that works for all content. Nvidia can simply allow the customer to decide what is un/acceptable flicker, while even keeping the ULMB2 and Pulsar modes separate.
BLooDS_inc
Post by BLooDS_inc » 01 May 2026, 11:49
kyube wrote: ↑
01 May 2026, 10:41
BLooDS_inc wrote: ↑
01 May 2026, 08:33
Cause? I'm use it and don't see any problem, use it even without vsync
brownvim
Post by brownvim » 01 May 2026, 16:27
kyube wrote: ↑
01 May 2026, 10:41
Precisely that
So I ended up settling on Pulsar at 360Hz with Special K locking the game to 320 FPS.
RTSS doesn’t seem to lock the frame rate as consistently as Special K in this game. You can see the FPS fluctuating a lot more on the monitor OSD with RTSS, which affects smoothness and clarity. Special K feels much more stable.
I also tried fixed ULMB2 at 360Hz, but I wasn’t maintaining high enough frame rates consistently for it to stay smooth. When I dropped down to 240Hz ULMB2 it felt nice and clean, but I ended up going back to Pulsar at 360Hz with the 320 FPS cap. My lows don't seem to go lower than 320 that's why I settled on it.
This feels like the best balance for me right now. Unless I can somehow get lower than 5–7 ms latency, I think this is as good as it’s going to get.
