Gaming monitors and upgrade from 24 inch to 27 give eyestrain
There are over 100 ergonomic issues from displays, far more than just flicker and blue light. This forum covers the giant variety of display ergonomics issues.
Abrikoos
Post by Abrikoos » 24 Aug 2026, 15:13
Hi,
I have been trying to figure out for 2 years now whats going on and why my eye hurts (lower eyelid) with new 'gaming' monitors. I also went to multiple eye doctors and nothing is wrong with my eye. I have some dry eye but get treated for that, and dont have problems with my old monitor and work monitor. My old monitor was a 1080P, 24 inch monitor and I tried only newer 27 inch 1440P monitors.
So far I tried the following monitors:
- LG 27GP850 (Nano IPS)
- Dell G2724D (IPS)
- ASUS XG27WCS (VA)
- AOC Q27G3XMN (VA, I still own this one cause I didnt return it on time).
- ASUS TUF Gaming VG27AQM5A (IPS)
- KTC H27E6 (IPS)
I still own the Asus VG248QE (24 inch TN) which gives me 0 eye strain. Also the monitors at work (Dell U2415) give me 0 eye strain. They are a bit older, so maybe something is going on with some new tech.. I also use low brightness, f.lux, etc etc. Like I said, i have been trying to figure everything out for 2 years now..
I saw the other post which helped (viewtopic.php?t=15321).
I am looking for a high refresh rate (240hz+) 27 inch IPS monitor which i Use mainly for work (working from home) and gaming (mostly CS2). I saw some recs from Kyube and also the big page he has with recs, but I also saw the KTC H27E6 in between the list of recommended monitors which still gives me eye strain.
I want to try the M27UP now (4k, 1080p) dual mode if its something that has to do with resolution..
I am open to try out anything (except OLED cause I dont wanna have a risk of burn in, or the feeling that it might occur). Maybe a YAG monitor however the options are limited...
Can someone push me in the right direction to try out more monitors over time? It has been a long journey so far.
Thanks in advance!
kyube
Re: Gaming monitors and upgrade from 24 inch to 27 give eyestrain
Post by kyube » 26 Aug 2026, 23:13
Abrikoos wrote: ↑
24 Aug 2026, 15:13
- Dell G2724D (IPS)
- ASUS XG27WCS (VA)
- KTC H27E6 (IPS)
All of those LCD's you've tried are KSF (PFS) WLED based displays
If you want QHD +240Hz YAG-based display (older narrow color gamut WLED backlight), get one of the following models:
The ASUS XG27AQNGV / ACER XB273UKF5 / MSI 272QRF / AOC AG276QSG2 (Pulsar panels)
If you want to limit yourself to <200Hz & QHD YAG, there's:
• Old G-SYNC module 120–165Hz IPS & TN panels (24" & 27", e.g.: S2417DG)
• AOC Q24G2A
The majority of other models in the QHD image res category are comprised of KSF (PFS) with seldom QD-based options, which I'll outline below as “alternatives”:
Alternatives:
• Zowie XQ2566X(QD TN 360Hz),
• MSI 274QPF X30MV (QD VA 300Hz),
• ACER XB273UKF (QD IPS 300Hz, EU-specific; predecessor XB273UGX is also QD-based),
• TCL 25P2A Pro (QD IPS 360Hz),
• TCL 27P2A Pro (QD IPS 320 Hz),
• Titan Army P245MS Pro / P275MS Pro (MiniLED Titan Army displays are QD-based),
• GIGABYTE M27Q2 QD (QD IPS 200 Hz)
& a few other chinese-brand models.
In the FHD sphere, all BenQ/Zowie models are either YAG or QD-based. Other vendors, in the FHD image res category, vary between YAG & KSF/PFS, with seldom QD models (like the TCL 25G64)
The highest refresh rate YAG-based FHD model is the Zowie XL2566X+, which is the successor to the Zowie XL2566K (also YAG)
The 540/600Hz Zowie models are QD-based.
Old 360Hz GSYNC module displays (PG259QN, AG254FG, AW2521H & others) are all YAG-based.
Everything else thats ≥360Hz FHD IPS is KSF-based IIRC.
In the 4K sphere, you got the KTC M27P6, MSI E16M, AOC U27G4XM and a few others (majority of MiniLED's are QD-based). No YAG in here.
The UW segment is probably the most disappointing one... QD-based options are as rare as it gets. The only one I know of is the old XG341C-2K
A few other ones can be seen here, most of which are not on the market anymore or haven't been released to the western market.
Abrikoos wrote: ↑
24 Aug 2026, 15:13
I don't see where I've recommended the KTC H27E6?... It's a standard KSF-based model, nothing special about it.
Abrikoos
Post by Abrikoos » 28 Aug 2026, 13:17
Thanks for replying. I appreciate it. So you think it might be because of KSF? The dell u2415 and VG248QE are YAG and QD?
In that case I will try a YAG monitor however the ones you mentioned are Pulsar and I have an AMD (9700xt) graphics card which would make the monitor a bit expensive since they cannot use the Pulsar technology. Are there cheaper YAG panels maybe with a lower refresh rate?
And OLED also wouldn't be an option?
The alternatives you mentioned then maybe wouldn't work for me right? Cause they are KSF or why did you list those? Cause they are QD? (Sorry I'm trying to understand).
Btw the ktc h27e6 was mentioned on the rentry page.
kyube
Post by kyube » 30 Aug 2026, 05:54
Abrikoos wrote: ↑
28 Aug 2026, 13:17
They are both YAG. Narrow color gamut.
Abrikoos wrote: ↑
28 Aug 2026, 13:17
The vast majority of FHD 120-240Hz models should be narrow color gamut (YAG)
I only have you the best in slot options for a gaming-oriented setup.
Abrikoos wrote: ↑
28 Aug 2026, 13:17
They're always a option to try.
Abrikoos wrote: ↑
28 Aug 2026, 13:17
The list of alternatives I've written here can work for you, as you haven't tried a single QD-based LCD yet.
My objective was to write out all available YAG & QD-based options on the current market that you have available.
From there on, you have to do some trial & error..
Abrikoos wrote: ↑
28 Aug 2026, 13:17
Oh. I have the H27E6 there only for the sake of it. It's not a desirable display experience to get in 2026.
You've reminded me to clear up the list now :D
Abrikoos
Post by Abrikoos » 31 Aug 2026, 06:23
Yes thanks. I will first try QHD and if nothing works then FHD.
Then it will also be on my list eventually.
Thank you, I will. I ordered the TCL 27P2A Pro based on your wide knowledge. AI says its KSF, then says its QD etc. I will see for myself ;) It is nowhere mentioned as QD though.. The 27C2A is QD apparently. The 95% wide color gamut makes it maybe KSF but we will see.
Im glad I helped you a tiny bit ;)
Abrikoos
Post by Abrikoos » 09 Sep 2026, 16:16
So here is an update. Unfortunately the TCL 27P2A pro also is not the right monitor.. I looked up the specs based on monitor info (EDID) and put all the info in chatgpt and it states it possibly also uses KSF and is definitely not a QD monitor. It still dries out my eyes way more than my old monitors.
Do you have any recommendations for QD 165hz 27 inch QHD?
Otherwise I'm thinking to try OLED, MO27Q28G, and otherwise the Zowie xl2546k or x (based on second hand price) or the Odyssey G4. Both 24 inch but I want to end this misery :(
kyube
Post by kyube » 10 Sep 2026, 06:52
Abrikoos wrote: ↑
09 Sep 2026, 16:16
Try another QD-based model I've mentioned above.
You could also attempt at getting the GB WOLED or QD-based panel, sure.
Abrikoos wrote: ↑
09 Sep 2026, 16:16
Unless spectrometer data or SPD graphs have been done, I can't confirm or deny that it's KSF.
GPT hallucinates and isn't a reliable source of information.
The best way to test whether it's KSF or QD is to use the backlight strobing feature (MPRT Plus)
A clearly visible red trailiing on TestUFO pursuit would confirm it being KSF.
QD can have slight trailing, but not to the extent that KSF does.
If you could record a pursuit photograph of this feature on 960 px/s or 1920px/s with a smartphone, I'd greatly appreciate it.
See this explanation by Chief
This would also give me an idea on how they'll implement MPRT Plus on the TCL 25P2A Pro.
Abrikoos
Post by Abrikoos » 11 Sep 2026, 17:06
I must say, it isn't that bad today. Still notice it though. It also stays sensitive for some days so I'll try the monitor a bit more.
It's definitely different than my YAG based monitor and work YAG monitor.
I tried to do the UFO test and capture it with the instructions. Kinda difficult and had to download a camera app to set the shutter speed.
I also made a video but can't seem to upload now cause the file is too large. If you want that as well I'll do it later.
Abrikoos
Post by Abrikoos » 13 Sep 2026, 04:13
So I bought the Oled and it triggered again my eyestrain.. possibly due to just bright colours or something. I have the feeling my eyes are over sensitive right now, so I need to take a break and try in a week or so again with both monitors. I will also consult my eye doctor again 25th to see if he knows what it might be (probably not, but worth a try). I'll keep you updated.
kyube
Post by kyube » 13 Sep 2026, 04:32
Abrikoos wrote: ↑
11 Sep 2026, 17:06
That's definitely a QD-based LCD, as there's no KSF fringing when using "MPRT Plus" (whose performance I'm disappointed with...)
Abrikoos wrote: ↑
13 Sep 2026, 04:13
Which OLED model?
