ELECTRICITY INPUT LAG.. HOW I FIXED IT?!
1nputlag34
Re: ELECTRICITY INPUT LAG.. HOW I FIXED IT?!
Post by 1nputlag34 » 04 May 2026, 07:06
Yazeedtt wrote: ↑
03 May 2026, 19:45
https://imgur.com/a/r9WsQiU
Is it possible that this damaged outlet attached to the electricity meter is the cause of the problem? I don’t even know why it is there in the first place like this.
Turn off all the circuit breakers in the electrical panel and leave only the one for your room on
jterri
Post by jterri » 10 Sep 2026, 03:18
1nputlag34 wrote: ↑
04 May 2026, 07:06
Yazeedtt wrote: ↑
03 May 2026, 19:45
Have you tested this? How did it feel?
1nputlag34
Post by 1nputlag34 » 10 Sep 2026, 06:48
jterri wrote: ↑
10 Sep 2026, 03:18
1nputlag34 wrote: ↑
04 May 2026, 07:06
Yazeedtt wrote: ↑
03 May 2026, 19:45
No change for me this helps you determine if a device in your home is causing the problem
astroasis
Post by astroasis » 10 Sep 2026, 15:14
You guys sure its not 2.4ghz signals? mine returned at my new house then i remembered i turned wifi on, its fine now with it off. Ethernet transmitting emi is fake news
MK92
Post by MK92 » 10 Sep 2026, 15:37
And what would wifi signal do to a PC? In theory a 2.4 ghz wifi signal could cause interference with a wireless mouse only, but if you have wired stuff its completely irrelevant and harmless
jterri
Post by jterri » Yesterday, 01:10
1nputlag34 wrote: ↑
10 Sep 2026, 06:48
jterri wrote: ↑
10 Sep 2026, 03:18
1nputlag34 wrote: ↑
04 May 2026, 07:06
Yazeedtt wrote: ↑
03 May 2026, 19:45
What do you think is causing the interference in your opinion?
