Could do with gamma and brightness, considering its only visible in certain shades of solid colors.Falkentyne wrote:Only way is to try different VT tweak totals.
Also the artifacts may vary between different monitors of the same brand, too. One of my VG248QE's showed this "scanlines" type artifact pretty obviously at 120hz lightboost, while a 2nd VG248QE barely showed it at all.
Thing is if I disable VT, I get a dark image and have to compensate with monitors own brightness setting and the clarity of motion such as testufo becomes less.
If I enable VT I get a brighter monitor and no need to raise brightness on monitor itself, and more clarity in motion with less crosstalk. But I get the scanlines.
