cant use the blurbuster utility
hi everyone,
i juste buy a xl2420g monitor from one of my friend... im trying to make it work with blurbuster but it doesnt seems to recognize my monitor .. didnt install any driver or firmware since i didnt find any on the benq website
anyone can help me with this ?
Re: cant use the blurbuster utility
Generic PnP Monitor In device manager ...
update monitor driver
i cant find them ...
Black Octagon
Hello,willpv06 wrote:hi everyone,
What is needed is to get Device Manager to show the full monitor model name ("XL2420Z", "XL2420G", "XL2720Z", "XL2411Z"). The default Windows 10 driver says "Zowie XL Series" which makes it harder for Strobe Utility to detect supported monitors, so you want to change your monitor driver until it displays the model the the suffix -- then Strobe Utility will work again.
(You'll also need to run Strobe Utility as Administrator as well, too)
There's a new version of Strobe Utility coming out later this winter (or spring) that is compatible with the "Zowie XL Series" driver, but there's a huge Blur Busters TODO still in progress at the moment.
Cheers,
Mark Rejhon
Im not sure which OS you're using but generally it should be found under Control Panel\All Control Panel Items\Administrative Tools\System Tools\Device Manager in all recent Windows versionswillpv06 wrote:hi everyone,
“Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind.”― Bernard M. Baruch
I think that Registry editing the monitor name to make it show in Device Manager, should also work too.
- lexlazootin
If you use the XL2420G with the blurbuster utility you can't be using G-Sync, you need to connect the monitor to your computer Via DVI and switch it to "Classic Engine"
I dont know but what I did help get tge strobe on because of the name this is working like a charm see my last post
