cant use the blurbuster utility
willpv06
Post by willpv06 » 18 Feb 2017, 17:48
hi everyone,
i juste buy a xl2420g monitor from one of my friend... im trying to make it work with blurbuster but it doesnt seems to recognize my monitor .. didnt install any driver or firmware since i didnt find any on the benq website
anyone can help me with this ?
willpv06
Re: cant use the blurbuster utility
Post by willpv06 » 18 Feb 2017, 18:08
Generic PnP Monitor In device manager ...
Q83Ia7ta
Post by Q83Ia7ta » 18 Feb 2017, 18:39
update monitor driver
willpv06
Post by willpv06 » 18 Feb 2017, 19:29
i cant find them ...
Black Octagon
Post by Black Octagon » 19 Feb 2017, 04:00
http://cee.benq.eu/download/file/5969
Sent from my iPhone using Tapatalk
Post by Chief Blur Buster » 19 Feb 2017, 12:50
willpv06 wrote:hi everyone,
Hello,
What is needed is to get Device Manager to show the full monitor model name ("XL2420Z", "XL2420G", "XL2720Z", "XL2411Z"). The default Windows 10 driver says "Zowie XL Series" which makes it harder for Strobe Utility to detect supported monitors, so you want to change your monitor driver until it displays the model the the suffix -- then Strobe Utility will work again.
(You'll also need to run Strobe Utility as Administrator as well, too)
There's a new version of Strobe Utility coming out later this winter (or spring) that is compatible with the "Zowie XL Series" driver, but there's a huge Blur Busters TODO still in progress at the moment.
Cheers,
Mark Rejhon
Stefan42
Post by Stefan42 » 20 Feb 2017, 04:24
Im not sure which OS you're using but generally it should be found under Control Panel\All Control Panel Items\Administrative Tools\System Tools\Device Manager in all recent Windows versions :)
“Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind.”― Bernard M. Baruch
Post by Chief Blur Buster » 21 Feb 2017, 00:31
I think that Registry editing the monitor name to make it show in Device Manager, should also work too.
lexlazootin
Post by lexlazootin » 21 Feb 2017, 06:06
If you use the XL2420G with the blurbuster utility you can't be using G-Sync, you need to connect the monitor to your computer Via DVI and switch it to "Classic Engine"
OKennobi
Post by OKennobi » 15 Mar 2017, 01:44
I dont know but what I did help get tge strobe on because of the name this is working like a charm see my last post
